Fitted a lexmark all-in-one printer to packard bell pc, worked ok (ish) then froze (the pc) -when switching on quite noisy (red light stays on on front) monitor when switched on has green light then automatically switches to amber after a few seconds - tried switching on and tapping both either f5 or f8 but cannot get safe mode - any advice please? thank you
  • 3,153 Answers
I would hazard a guess at a possible power supply fan about to fail or cpu fan issue maybe causing an overheat problem.
I have included information for both below
disconnect the computer and take it outside. Open up the case and check for gunk on the fans and the PSU grills.
Take a can of compressed air meant for cleaning computere and blow as much as you can out (dont poke the nozzle into the PSU and waer glasses)
Computers they are designed nowadays to shut themselves down if there is a problem
What you should do is check the fan assembly and if it is loose at all that would give good reason to do what I am going to advise.
Disconnect the fan from the board.
Check your manual for the exact instructions but you should remove the cooler completely
DO NOT REMOVE THE CPU
Now with nothing more than isopropynol and cotton bud sticks or another alcohol based cleaner remove the old thermal grease / sticker from the top of the CPU (make sure it is clean)
At this point it is up to you but you could consider a newer better cooler
You could take your old cooler to a good computer shop show them it and just ask for a better one
If you are using your original cooler then here we go
Do the same with the underside of the cooler.
While the cooler is off it may be worth giving it a good 8low job
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business.
Another consideration is that many cases have places in them for extra fans and usually extra connections on the motherboard too.
They are quick and easy to fit.
Quite often I will fit TWO in what is called a push/pull configuration. One pulls cool air in while the other pushes hot air out
Ok now for PSU
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard) also disconnect any drives. (REMEMBER HOW THEY WERE CONNECTED ! digitalcamera may be useful there) and power up
If you hear any beeps these can indictate where the fault is.
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 05, 2009
  • Computers & ... Master
  • 928 Answers
Get the memories card out and clean them up. 90% of the time is the memories card. While you do this, unplug your computer for a good 10 minutes. This suggestion is in case you don't get any video because of a hardware malfunction. If it's not the RAM, then most probably, you need another MB.
Packard bell laptop only power light works and fan stays on all the time
This is a motherboard issue, in order to go any further the main board must be evaluated to see if it can be repaired.
Jun 20, 2012 | Packard Bell Computers & Internet
Packard bell imedia VL Light desktop not displaying on screen
I just bought a packard bell VL light i media and believe the noise the fan produce inside the system unit is quite unbearable.
Oct 28, 2010 | Computers & Internet
My packard bell ixtreme 5830 wont turn on. the light stays orange instead of green can anyone help
if it beeps there is a memory problem inside if not turn it on so its orange turn it a round and flip the the red switch on the back of the power suppy, multiple times and then start turning off the computer, ive got that to work it could just something dumb with the power supply
Jun 11, 2010 | Packard Bell ixtreme 9222 (P491000102) PC...
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
Printer z845
Go to Lexmark.com
They have a link to drivers. Also probably a link for troubleshooting.
Mar 23, 2008 | Lexmark Z845 InkJet Printer
Packard Bell Easynote R1802 Switch Off When Battery is plugged in
The battery is probably faulty, try a different one. If it does the same thing with a different battery, then must be a short in behind the battery socket on the laptop. In that case better take it to service.
regards
Mar 05, 2008 | Computers & Internet
Packard Bell EASYNOTE M5262 can't b turned on
Nothing runs on 240volts, execpt some house hold appliances like an electric dryer. I think you bought the wrong adapter. Click the link below & it will take you to your notebook.
Scroll down to "Power".
http://support.packardbell.com/uk/item/index.php?pn=P880400301&g=1400
AC Adapter FSP120-1ADE21 Specifications. 07-05-2004
Just hope it hasen't hurt your notebook.
Luck!
please vote.......
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Packard Bell Store and Save H2D2U2 6948840100
mine doesn't register on the c drive when i turn it on. Occasionaly I get access, but then the computer crashes. My main drive is Nftls the external drive is configured to Fat 32, could this be the problem? Altho, I'm not so sure as it's been working ok for the past year. I managed to scandisk and fix errors and managed to defrag, everything was working pukka after that, but then today.. well that red light is annoying, especially when you dont know what it means! Think I need to go to packard bell and see if they have a solution. Anyone found one yet?
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
