Question about Amana ARS266ZBS Side by Side Refrigerator
Automatic defrost not working, but manual is?
I have an Amana ABB2222FEW bottom freezer refrigerator. The refrigerator was warm but the freezer was icing up (plugging up the vent). I checked voltage on the defrost thermostat using "Service Test 1" and a voltometer... ~20V or so open, 120V closed. With the relay voltage confirmed, I figured my defrost heater was bad, but when I plugged it back into the defrost heater, it heated up and quickly defrosted the coils! So, now I confirmed the defrost thermostat is working, the defrost heater is working, and the fans are all working. It seems for some reason the refrigerator just wasn't going into defrost mode automatically. I'm waiting a few days now to see if it ices up again. If it does, what do I need to do to avoid having to run a manual defrost every week or so... do I need to replace the control board?
  • 4,059 Answers
Yes if the heater and defrost thermostat are good then the problem is the control board.
Posted on Sep 04, 2009
Amana fridge abb2222few not cooling but freezer is working where is fan motor located for fridge section
its in the freezer near the top if its not cooling I would check ur air damper flow control, is it to far close or opened? check the cold control thermostat, the thermistors. and of course the fan itself, check door seals.
Mar 17, 2015 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The refrigerator is 2 yrs old and has completely quit cooling in both the refrigerator and freezer.
I looked at your wiring diagram. This ice box has automatic defrost controls. That means the temp is regulated by a computer board. Their are some diagnostics you can perform on some of these models.
Your ice box appears to be a midrange control model. Click HERE for a diagnostics video
Amana International bottom mount service manual featuring midrange electronic controls
Jan 27, 2011 | Amana ABB1927DE Bottom Freezer...
My Amana ABB2222FEW refrigerator is not cooling, but the bottom freezer is working fine. What can I look for?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | Refrigerators
Top refrigerator warm bottom is ice cold.
An automatic defrost time turns the defrost cycle on and off every 24 hours. If problem continues, problem is most likely defective defrost timer.
Even electronically controlled units often have electro-mechanical timers for defrost cycle.
Jun 15, 2010 | Amana ABB1927DE Bottom Freezer...
Bottom freezer frosts up,top refridge gets warm
It sounds like you have a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator warm but freezer is fineChanged the evaporator fan (12013211q)for BR18Ve Amana...Is it possible that the part last only a couple of years...
If your bottom freezer has ice build up, (you will see it frosted up), you do not have proper air flow. Check to see if your defrost elements are working. They are in the freezer compartment. in the evaporator. There is a defrost timer on the bottom of your fridge. You can turn the knob until the refergerator turns off, then listen in the frezzer compartment to se if the elements are working. (You will hear them sizzle)
Aug 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Amana ARS266ZBS Side by Side Refrigerator Logo
522 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
