Question about Avid Cycling
I Have a 5speed Broadmoor mountian bike cannot adjust gears any suggestions
  • 484 Answers
When you say adjust, do you mean shift or do you mean adjust? You should start with the easiest solution: give your drivetrain a really thorough bath by using Simple Green and a brush to clean it really well, then lubricate your chain with the proper chain lube. If the problem persists, e-mail me and i will give you a detailed description of how to adjust the drivetrain.
Posted on Sep 07, 2009
How do I adjust 7 speed shimano on Huffy?
Cable adjustment is complex. Suggest taking your bike to local bike shop for assistance
Sep 08, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
How do I get the gears to work again on my Schwinn Mesa GSX Mountain Bike?
The shift cable is likely too loose, but there are multiple items to tighten, lubricate and adjust on just the derailleurs, let alone the rest of the bike, before it's safe and ready to ride. I would suggest you get some assistance from a more knowledgeable friend, a bike co-op or a bike shop.
May 18, 2017 | Cycling
I have a SRAM 3.0 rear derailer. It is difficult going into the two largest gears, I have a 7 speed cassette. I notice there is no barrel adjustment on it. Any suggestions
The barrel is for fine tuning the indexing among the gears. Limit screws set the inner and outer physical swing of the derailleur.
A simple web search for "Sram 3.0 Mountain Bike Rear Derailleur adjustment" finds the manual.
http://www.sram.com/_media/techdocs/RD_X0_X9_X7_5_4_3_QS_03.PDF
There IS a barrel adjuster.
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Aug 10, 2011 | Sram 3.0 Mountain Bike Rear Derailleur -...
This question is for my 2005 Honda CRF150F.My bike when rididng in the mountians and down here in town seems to have a problem. When I throttle up to go faster the bike sputters and sounds like it is...
Chances are that water condensation in the gas tank has collected in the carb float bowl. There should be a drain plug on the float bowl. Go ahead and drain the bowl with the gas valve turned off. After the bowl has drained, turn the gas back on and let the gas tank drain a half cup or so. This should rid the tank of water. No adjustments are needed. Your carb has a plug on the bottom of the bowl. Please rate my answer. Thanks. tombones49_180.gif
Jun 19, 2011 | 2005 Honda CRF 150 F
How do i adjust my rear disc brakes on my appollo vulcan mountian bike?
Download the Apollo Owners manual for overall advice.
http://www.apollobikes.com/downloads
It says to check the brand of the brake and refer to ITS manual.
I can't find what that brand and model might be for your bike.
Once you determine it, Google search for the company and a manual.
With Avid being the most comon of mechanical disc brakes, you may find this helpful...
http://www.parktool.com/blog/repair-help/avid-reg-mechanical-disc-adjustment
May 17, 2011 | Apollo Cycling
My 1997 madza b2300 5speed manual shifter 4 cyclinder pickup cant change gears with motor running with engine off can change to any gear whats wrong with truck
Here are some suggestions for you to try.If there is any kind of adjustment try that first.If that doesn't work then I would have your clutch inspected for extreme wear if it hasn't been changed.
Mar 06, 2011 | 2007 Mazda B2300
Hello there! My mom just bought me a $300 Schwinn Melee from a Fred meyers in Newport Oregon. Beautiful Bike However there wasn't any instructions about the Shimano gear shifters. I'm doing something...
first identify the problen is it front or rear derailuer.secondly bike shop mechanic hate cheap mass produced bikes because they do not sell them
so lets solve your problem,okay sometimes this can be an adjustment issue.now if its bunching on front then first read your owners manual to see which gears are compatible,sometimes it will suggest not using certain gears,secondly if yhe chain has fallen off and got jammed it may be bent and need replaced visually confirm if the chain is straight.okay if it is not the chain then the length and length adjustment can be changed using the adjustment on the rear derailuer look and you will see 3 screws located on it the two with L /H are for adjusting the gear stops l is for low gears,so it does not go too far and wedge between the gear and spokes,H is for the small gear(high)if it goes past and falls off adjust this one.lastly the one located at the very rear adjusts chain tension the loosening of this one will relax the chain and apply more chain on the gears   tightening of this one will tighten the chain,adjusted properly your chain should not bow down over adjustment will cause chain skips.now if there is too much slack in the cable that is adjusted by the adjusters on the ends of the cable where it meets the shifters,learning to adjust your bike will save you a lot of money in the long run.
hope this helps
Jul 14, 2010 | Schwinn Cycling
I have a 5speed manual transmission and it sounds as if the gears are grinding while driving in all gears. The transmission shifts ok, and does not slip, just makes the noise. Can the gears be out of...
The clutch needs an adjustment. What's happening is the clutch isn't completely engaging while you shift, causing the grinding. Once properly adjusted, the grinding will disappear.
Oct 25, 2009 | 1990 Nissan Maxima
Clutch friction is middle ways instead of grabbing from floor.
should be auto adjusting, clutch is probably going out, you will notice it beginning to slip in high gear as it wears out more
Apr 23, 2009 | 1997 Isuzu Hombre
Coolant and engine oil levels?
the oil level is max upper line on the sight glass on engine/ coolant level is max at upper level of expansion bottle as to the gears from neutral first is up and the rest are down
Feb 14, 2009 | 1992 Suzuki VS 800 Intruder
Cycling Logo
49 people viewed this question
Top Avid Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
John Egan
John Egan
Are you an Avid Cycling Expert? Answer questions, earn points and help others
