Question about RTO Mini Quads
Need to know how to set throttle so it will only go so fast.
  • 29 Answers
HELLO; If I understand you right you are looking for a way to set the limit on the throttle, right? If so it's easy, there should be a set screw on the throttle houseing with a jam nut loosen the nut and turn in the machine screw while pushing on the thumb butterfly. Set it and ride it around and see if you are happy with the speed, if so thghten the jam nut and your set. GOOD LUCK.....GREASY
Posted on Oct 13, 2009
I have a 49cc chopper and the idel is not workin what can i do to fix that
Posted on Mar 12, 2012
  • 867 Answers
Check at carb if any adjustments, also at throttle grip, if none, cable may be stretched and needs to be replaced
Posted on Sep 04, 2009
Very high idle after rebuilt carburetor on Chevy 250 l6. Choke is okay, no fuel leaks. Engine races at about 3000 rpm
Sounds to me like the throttle plate is too far open at idle. Look for something hanging up and holding the throttle more open that it should be-like the choke like the auto choke or the fast idle cam screw set to far in. Look up the fast idle speed adjust procedure in the books and check out how yours is set up. Also, if the carb was all the way apart the throttle plate may be off center on the throttle plate shaft causing extra air to bypass the throttle plate. Good luck.
Jan 03, 2015 | Cars & Trucks
Tick over too fast even though throttle is at its lowest setting ,fordson dexta
Then try enriching the L speed mixture a little may burning fuel too lean.
Dec 15, 2014 | Garden
How do I adjust the thorttle settings?
follow the throttle cable down to the throttle plate you should see a screw with a clamp holding the cable loosen it up pull back on the throttle cable a little tighten the screw down see if it works better as for as the govenor its tricky better left to a mechanic because engine might rev up and blow crank so leave it to them start when you pick it up if sounds to fast have them adjust it right then charlie
Jun 06, 2014 | Husqvarna 21" Lawn Mower with Honda GCV160...
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
My husqvarna 254 run great but she idle too fast ,ill set the low needle and when i set the idle one nothing chang
Machines that idle too fast and eill not alter with the idle screw either has the throttle butterfly on the throttle spindle loose and sticking, or the machine is drawing in air through a crank seal or gasket.
Jan 18, 2013 | Garden
1969 Datsun 1600 pickup Fast Idle
Could be the fast idle cam for the choke. When the choke is closed the fast idle cam holds the throttle open until the choke opens.
The cam should be on the opposite side of the throttle cable.
Aug 14, 2012 | 1969 Datsun 1600
My 88 chevy cheyenne has a problem with a fast idle. I don't know how to slow it down. It is a fuel injection throttle body set up. I can't afford to just start replacing parts till I find the problem. Any...
One easy thing you can try is spray some carb.or brake cleaner around the throttle body area.The gaskets on these were known to go out and this will cause a fast idle.The other thing is make sure the throttle cable or linkage is not sticking or binding.Hope this helps.Good luck.Let me know what you find out.
May 10, 2010 | 1988 Chevrolet C1500
I need instructions on how to adjust a carburador in a yamaha Tw 2001
Turn the throttle screw and air screw inward until they LIGHTLY seat. Now open each of them one and one half turns. This is the factory setting. Now set the desired idle speed and then adjust the air screw for the fastest idle speed at the current throttle screw setting. If now too fast, reset the throttle and then reset the air screw to match.
Jan 02, 2010 | 2002 Yamaha TW 200
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
RTO Mini Quads Logo
280 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
