Question about SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive
My usb device is not formatting - SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive
  • 41 Answers
u can format ur pendrive through the window xp cd,.........insert pendrive,.......than boot ur system ,.........follow instructions................after that when dialogue comes format c,d or e drive ,....choose the {~?~} drive {ur pendrive}................
enjoy
Posted on Dec 05, 2009
  • 106 Answers
It is due to virus problem take this pendrive to another computer and u can do the formatting. if that is not possible then try deleting some files nad do the formatting or format ur machine and do the formatting or none of the solution works then the usb disk is corrupted.
Posted on Sep 05, 2009
HOW DO I USE THE USB PORT TO PLAY MOVIES
Tom,
To be able to play movies stored on a USB device (it doesn´t matter if it's a usb pen, a usb hard drive, etc), you will need two things:
1.- The device where you want to play the movies must support the USB device that you're using (not all USBs are the same, and they can be formatted differently, too). So if when you plug it in, the TV doesn´t recognize it, use a different USB device.
2.- The movies that you put on the USB device must be palyable by your device. ie: your TV, BluRay, etc must be able to decode and play the movie format, and this can be AVI, DIVX, XVID, H624, QT, MKV, etc. Even if your device reproduces DIVX movies, if the movie is encoded in a weird format, it won't be playable. The fastest way to know is trial and error.
Feb 09, 2015 | Hard Computers & Internet
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
TV is not showing the USB data
maybe you did not properly select the right application in your tv... example if you play movies go to movies menu and if thats music go to music menu and also for pictures go to picture menu......or the format of you data is not supported of you TV..
Jan 12, 2014 | Computers & Internet
HOW TO format kingston usb 2.0 usb device
Sir select your kingston usb device on a my computer window right click to get option select format option you will get the window select quick format and hit format button to format it.
Apr 10, 2011 | Kingston 2GB Secure Digital Memory Card
When I put my DaneElec 4GB USB Drive into my USB port, nothing happens. We have Vista.
Do other USB devices work when you plug them in the USB port?
If they don't then you have a faulty USB port otherwise the DaneElec is faulty or needs formatting.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 18, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Transcend JetFlash V60 16 GB Pen Drive not working properly
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
Oct 05, 2009 | Electronics - Others
Usb problem
Plug in usb drive, click my computer and locate usb device in windows explorer. right click on usb device and choose format.
May 17, 2008 | Linksys USB200M USB 2.0 Network Adapter
Formatting tritanium 1GB cruzer USB Drive
u should try to format it using memory card reader in PC like as other drives or devices.
simply right click on the new drive of memory card and click on the format. It will be formatted. and ur problem is solved.
looking for ur feedback
Sajan.
Apr 30, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
My memory stick quit!
try using startup disk of windows xp,, its very sensitive..be carefull... .. then be sure that your usb is connect to the computer.....del the partition of usb device.... then create partition, last format it... be carefull that you want to format is your usb device not your hard drive.
goodluck..
Mar 19, 2008 | Computers & Internet
USB Drive
Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive Logo
776 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
