Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
COLOR KP-46WT500 Everytime turn on, left and right side of TV has light yellow ( not in center) and picuture also has blue background.
  • guJupLaYa Dec 09, 2007
    same exact problem. This happened to me TWICE. there is a different contrast in color. It fixed by itself when i pressed "system off," however I doubt that has something to do with it. Maybe the video card is faulty I have no clue. I also highly doubt u have to change the contrast and brightness, etc. The problem goes away then comes back again on the lower left hand corner. Its a little blob of yellow-blue contrast.
    Problem Solver:
  • 12 Answers
Some people have a scale on their T.V. somewhere, or for most cable users it shows on the menu an area where you can change contrast, color, tint, brightness, ect...
Posted on Dec 08, 2007
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Aug 03, 2011 | Sony KP-46WT500 46" Rear Projection...
Blothes of color in center and right side of screen. Very noticable when it's a light background.
May have burned CRT(s), (if you are not talking about convergence.) Burned CRT shows when that CRT (R,G,orB), does not show in an area of the screen where it should. Check bright white color = full R, G, and B CRT brightness. Gray = mid RGB brightness. Yellow = R+G(no B), Blue-green = B+G, no R, etc.
Apr 12, 2010 | Sony KP-53V75 53" Rear Projection...
I have a Sony TV that needs help...model# KP-46WT500. Issue is, turned it on this morning and Red Green and Blue are no longer lined up. You can see three images in every color. it's looks better in the...
Convergence is dead.Must replaced 2 convergence ICS,and some or all it resistors.Can u do soldering electronics parts?Buy a convergence kit at websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 25, 2010 | Sony KP-46WT500 46" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
CircuitCity
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
