Question about HP DeskJet 940c InkJet Printer
Replaced both ink cartridges light still flashing
I,ve replaced both ink cartridges and the amber light continues to flash and i can not printit won't read the black ink cartridge
Flashing light opposite ink symbol
Indicating cartridge faulty/exhausted, replace the cartridge..
Oct 11, 2011 | HP DeskJet F380 All-In-One Printer
How do you load new printer cartriges
To replace an ink cartridge using the fonth.gif ink button, follow the steps below.
1. Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
2. Lower the output tray, then open the printer cover.
3. Press the fonth.gif ink button. The print head moves to the ink cartridge replacement position, the fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not apply excessive force to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. This process takes about one minute to complete. When the ink charging process is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
Nov 19, 2010 | Epson Office Equipment & Supplies
Poor black print quality black prints greenish grey
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Office Equipment & Supplies
Amber light is blinking, error message when printing
Generally means that you're out of ink in your ink cartridge. Note that the NUMBER of times it flashes is significant: if it's 2 or 3 flashes at a time, then it's a paper problem (jam, out of paper, etc.), otherwise it's an ink problem (replace the cartridge).
Oct 14, 2009 | Canon PIXMA iP1600 Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Apr 09, 2009 | Office Equipment & Supplies
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
HP DeskJet 940c InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
