Question about Watches
TOOK WATCH COVER OFF TO REPLACE BATTERY ON A ACQUA AND CANNOT GET COVER BACK ON
Make sure the battery placement compliments the locking spring or wire allowing the back cover to go on. start by applying pressure to one side of the lid and gradually make your way around the perimeter applying steady pressure as you go. afew snapping sounds let you know progress is being made. good luck!
Posted on Feb 27, 2011
Need to know what size battery goes in a acqua a4a601 ladies dress watch
i can replace battery oldgoldguy03 yahoo . you need to seal the watch too .
Feb 01, 2012 | Watches
How to do I replace the battery?
i don't have one of these watches, but i took a look at a picture of the back. at the back, there's a slightly raised lip. this is the back cover. get something sharp like a knife, and just slip it under that lip and pry it open. that should give u access to replace the battery.
Aug 07, 2011 | Diesel DZ2062 Wrist Watch
I have a small acqua watch and after replacing the CR1612 battery i can't seam to get the cover back on. there is no notch on the back cover so orientation may be a problem. the only markings on the back...
I suggest that arrow points to where the case back should be opened. Check if there are any writings on case back. When the watch's opened back is facing you (winder to the left), these letters should be normally readable (not upside down) with case back attached to watch. If there are no writings, check inside case back - there should be small groove on one side. This side should be aligned with the stem (the piece going from winder into watch).. Hard to say without seeing it, but hope it helps. Be aware: to fit the case back back on watch may require significant force.
Feb 27, 2011 | Relic (0504529FA)
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
  • Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • OR take to a professional jewelry store/watchmaker.
    Good luck.
    Aug 21, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Hello, I just bought a Timex Acqua with Indiglo
    Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
    Aug 18, 2010 | Timex 2J611 Watch
    I'm trying to replace the battery, in my mother's Indigo Acqua watch. I can not get the back off?
    If you are struggling with the back then the best advice I can give you is to take to a local jeweler as they have the correct equipment to do batteries, easily and without damage to your watch. Most batteries are going to be less then $15 and its worth it to not have the headache and damaging it if unsure what to do
    Aug 11, 2010 | Watches
    I NEED THE INSTRUCTIONS MANUAL FOR AN ACQUA INDIGLO MEN'S WATCH. hOW CAN i FIND IT?
    mcdevito75 here, You can visit Acqua Indiglo.com or check with a small watch repair shop in your area.
    Jun 28, 2010 | Bulova Watch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    Acqua Indiglo watch
    Can't understand instructions
    Aug 31, 2008 | Watches
    Watches Logo
    311 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
