Question about Whirlpool Inglis IP8200 Dryer
Wiring an electric dryer
What type of wire to use when hooking up an electric dryer
  • 1,543 Answers
If you are referring to the breaker / fuse box to the dryer recepticle, you would use 10-3 NM w/ ground. (that is 4 conductor wire: 2 "hot", one neutral, and one ground.) If you are referring to the dryer to the recepticle, use a pre-made dryer cord, either a 3 wire or 4 wire, depending on which recepticle your home has.
Posted on Sep 04, 2009
I have a 3-wire hook-up. Can I hook-up 120 by wiring a 120 wire connection?
No you cannot hook this dryer up to 120. It takes 240 volts to run motor and heater element.
Jun 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Neptune MDE5500AY Electric Dryer: electrical hook up...
If this dryer doesn't have a cord, you need to go to hardware store for a dryer cord, usually 4 wires 30 amp. the black and the red wires connect to the 2 brass screws with red and black wires already on the other side of the terminals. (oh, you should use a strain relief connector to run thru the knock out (hole) for the cable. The white wire connects to silver screw, which should have a white wire on the inside connection. Now the green wire connects to the green terminal, if there is one, or any other screw that should be marked as ground on the inside somewhere.
This should do it unless you don't have the dryer receptacles wired in yet.
May 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to install 3 wire cord to 4 wire range
Here is a wiring diagram for the 3wire and 4 wire hook ups for a electric dryer ..
Mar 28, 2010 | Frigidaire GLER341A Electric Dryer
I moved into a house that has the 4 prong dryer receptacle and I bought the new 4 prong plug to hook up to my dryer but there are only 3 wires on my old one. The new one has a red, green, white and a black...
be careful the voltage may be different thats why they make them with different plug configurations. check your dryer voltage requirement. usually the four wire type are for 250vac electric dryers.
Mar 06, 2010 | Dryers
TRYING TO HOOK A 3PRONG CORD WHAT TO MAKE i"m doing it right
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
3 prong 4 prong
Aug 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Hooking an electrical dryer to a breaker
You will typically need a 40 amp 220V circuit for this ( check with local building inspectors).  You will need to run some hefty wire probably #8 three wire  (again check) and install the type of plug receptacle that is on the  dryer cord.
Inside the breaker box you will need a dual breaker 220V breaker rated at 40 amps.  The wire coming into the breaker box will need to be clamped in place with appropriately sized wire cable clamp where the enter the box through a knockout- available at any hardware store.
Now the big question-  why are you switching to electrical?  Gas is pretty much half as expensive as electricy  and will dry the clothes faster (usually gas dryers generate more heat than electrical ones).   Just wondering..
Oct 20, 2007 | Dryers
Whirlpool Inglis IP8200 Dryer Logo
91 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
