Question about Watches
TOOK BACK OFF A ACQUA WATCH TO REPLACE BATTERY CANNOT GET BACK ON
4 Suggested Answers
  • 172 Answers
SOURCE: How do I open the
Your watch has a snap-fit case; the back is simply pressed back into position with firm pressure. The problem is that modern snap-fit case backs are often very tightly fitted to increase their water-resistance--they're tough to get off, and even tougher to push back into position. I would not be surprised if you will ultimately need a jeweler's case press to get the back of this watch back into place (more on this later).
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. Many Timex watches have a small triangle / pointer etched into the case back to suggest where you should fit a case knife to pop off the watch. If you don't see that small raised section or a marker (Aqua is a discount brand of Timex), you'll need to choose a location to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose.
If you can't press the back on securely after replacing the battery, you will need to use a case press to complete the job. A case press is just what it sounds like: a device for clamping watch cases back together. It's designed to provide an equal amount of force around the edges of the watch back without putting that same pressure on the watch crystal (which could cause it to crack or break). I'm aware of two basic styles. One style looks vaguely like a big pair of pliers, but with two swiveling plates instead plier jaws. The other style, which I prefer, sits on a table or workbench and uses a lever to push down the top plate. In both cases, nylon jigs are inserted to match the size of your watch.
You can find case knives, case presses, and other watch repair tools at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for an extremely reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
If you can't close the watch case with your bare hands and don't have access to a case press, your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
Posted on May 30, 2011
gemineye61
  • 831 Answers
SOURCE: I'm trying to replace the
If you are struggling with the back then the best advice I can give you is to take to a local jeweler as they have the correct equipment to do batteries, easily and without damage to your watch. Most batteries are going to be less then $15 and its worth it to not have the headache and damaging it if unsure what to do
Posted on Aug 11, 2010
SOURCE: TOOK WATCH COVER OFF TO REPLACE BATTERY ON A ACQUA
make sure the battery placement compliments the locking spring or wire allowing the back cover to go on. start by applying pressure to one side of the lid and gradually make your way around the perimeter applying steady pressure as you go. afew snapping sounds let you know progress is being made. good luck!
Posted on Feb 27, 2011
Lost my Acqua Indiglo Digital wristwatch User's Manual...how can I get another?
Acqua watches are made by Timex. For a manual for any model, go to https://www.timex.com/watch-manuals.html
and choose your watch.
Oct 15, 2017 | Acqua Watches
Need to know what size battery goes in a acqua a4a601 ladies dress watch
i can replace battery oldgoldguy03 yahoo . you need to seal the watch too .
Feb 01, 2012 | Watches
I have a small acqua watch and after replacing the CR1612 battery i can't seam to get the cover back on. there is no notch on the back cover so orientation may be a problem. the only markings on the back...
I suggest that arrow points to where the case back should be opened. Check if there are any writings on case back. When the watch's opened back is facing you (winder to the left), these letters should be normally readable (not upside down) with case back attached to watch. If there are no writings, check inside case back - there should be small groove on one side. This side should be aligned with the stem (the piece going from winder into watch).. Hard to say without seeing it, but hope it helps. Be aware: to fit the case back back on watch may require significant force.
Feb 27, 2011 | Relic (0504529FA)
I received a used Acqua Indiglo watch recently which appears to work but I have know idea how to set the functions. How can I attain a manual? Thank you
This web page explains how to set the watch:
http://wiki.answers.com/Q/How_do_you_set_time_on_a_acqua_indiglo_30m_watch
Also, if you google "Acqua Indiglo manual" you will find many other articles that explain how, in case that one doesn't work (but it should).
Hope this helps.
Dec 15, 2010 | Watches
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
I'm trying to replace the battery, in my mother's Indigo Acqua watch. I can not get the back off?
Aug 11, 2010 | Watches
I NEED THE INSTRUCTIONS MANUAL FOR AN ACQUA INDIGLO MEN'S WATCH. hOW CAN i FIND IT?
mcdevito75 here, You can visit Acqua Indiglo.com or check with a small watch repair shop in your area.
Jun 28, 2010 | Bulova Watch
TOOK WATCH COVER OFF TO REPLACE BATTERY ON A ACQUA AND CANNOT GET COVER BACK ON
Sep 04, 2009 | Watches
Acqua Indiglo watch
Can't understand instructions
Aug 31, 2008 | Watches
Watches Logo
565 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
