The color is totally off on our TV after we replaced the bulb
  • 157 Answers
Dlp tvs also have a color wheel if you post the model number i will give you the part number
you can also google color wheel with model number to find it
Posted on Sep 04, 2009
I have Zenith rear projection TV Model IQC60H95W.The blue tube does not work. The red and green project. Is this a bulb or tube and are they available to purchase? The TV was made in 2001
This is a CRT(cathode ray tube) not a bulb. A Bulb is totally different. If you replace one Tube, you need to replace all 3 or the colors will never match properly. However, This model no longer has parts available. Even if they were, the cost would be close to $1000 in parts. I would not recommend repairing this TV.
Sep 14, 2014 | Zenith Televison & Video
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
The screen is almost totally black.
You may need a new projector bulb for your tv. Search for "JVC Projection TV Replacement Bulb" + your tv model number on amazon.com and you should be able to find one.
Once you have the bulb, refer to your TV manual to install the bulb.
Apr 22, 2011 | JVC Televison & Video
Purchased a new bulb for our Samsung HL-T4675SX DLP TV in October. Less than 3 weeks after the bulb was installed, the TV would not turn on and the three indicator lights on the front of the TV came on,...
ballast failures are not that common in general. i would suspect the color wheel before the ballast. do you hear a whirring noise when the tv is trying to turn on. sometimes the color wheel will not spin correctly and the tv will not start as a result.
Dec 23, 2010 | Samsung HL-T4675S Television
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Thomson 50DSZ645
There is only one brightness bulb for your tv. You have the main bulbs which run the color for the Tv and then you have another bulb which runs the brighness. Typically it is a flourecent bulb inside which does need replacement now and then. Check tje specks on the tv's web site and you should be able to get the model number of the bulb from them and you should be able to purchase it from a repair shop or from online
Oct 23, 2008 | Thomson 50DSZ644 50" DLP Rear Projection...
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
