How do i replace an ssb board on a 42" phillips lcd flat screen. Can I do it myself.
  • 188 Answers
This depends on the set,sometimes you need the have Compair to install some software.
If you have a complete panel from a scratched unit it's easy to replace it yourself.
Posted on Sep 04, 2009
Phillips 42 Lcd screen cracked is it just Phillips Lcd tv screens that fit or does any 42 Lcd fit
Not going to use one from another set even if same brand, frankly this is usually a waste of time as if the screen was damaged and the set was on or was at any time after powered up one or more boards in that set may now also be bad.
Buy a new set.
May 22, 2012 | Philips Televison & Video
I have philips 42'' lcd tv its only 14 months old i have no picture but have sounnd is my tv still under waranty thanks gary
You need to replace the SSB [small signal board] I don't beleive warranty work will cover this. Reach into your pockets for this one! Sorry!
Mar 14, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Philips Tv always returns to menu screen
ssb board failing need to be replaced encompass.com
Sep 17, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a phillips 42'' lcd tv and was told that i need to replace my ssb board and it would cost 500 dollars. how can i fix this myself if i buy the part
ssb board should be available thru tristate module or pts electronics-if you give them the model number they can give you the price
Sep 04, 2009 | Televison & Video
Phillips ssb
It is pretty much a plug and play. It is more time consuming than any degree of difficulty.
You must make a strong mental note of where each screw goes.
Simply disconnect the Molex connectors and the screws on the Signal Board; you're pretty much reverse the process. No cutting or soldering is required!
Dec 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Problem with the HDMI input
check with another source or cable. you likely have a bad hdmi input, this would require a new SSB module to fix.
Dec 07, 2008 | Philips 42PF9830A 42 in. LCD Television
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
PHILIPS PALSMA TV SSB BOARD
I was unable to locate the part number 310432838731. The SSB board for model 42PF7320A is located below.
Philips 42PF7320A Replacement Small Signal Board
Apr 14, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No video
PROBABLY NEEDS SSB REPLACED BUT YOU WOULD HAVE TO DO SOME VOLTAGE TESTS TO BE SURE
Feb 19, 2008 | Philips 42PFP5332D 42 in. Plasma...
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
