Question about Panasonic KX-P4420 Laser Printer
KXP-4420 will not power up.
After months of inactivity (and removal of power) the printer will not power up. No lights, no spin-up noises, no display activation - nothing. All fuses test good and there are no obvious signs of failure (burnt components, blown or leaking capacitors, etc.) in the power supply. Any ideas?
    Problem Solver:
  • 5 Answers
I am interested in buying this printer Panasonic LaserPartner KX-P4420 in any condition working or not. Pete (847) 201-1612
Posted on Nov 18, 2012
No power Panasonic kxp 4420
I would like to buy your Panasonic KX-P4420 Laser Printer in any condition working or not. Pete (847) 201-1612
Feb 12, 2011 | Panasonic KX-P4420 Laser Printer
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
4420 set to Central Time with Automatic Daylight applied reverts to Standard Time at power on ... has Daylight Savings not been applied ?
From the Start menu, select Settings >
Control Panel > Date/Time
to open the
Date/Time Properties control panel.
Use the arrows in the application to
navigate, increase or decrease the
time or date.
2. Select the year to open a field where
you can change the year by backspacing,
or entering a new year.
3. Select the month to open a pulldown
list of months.
4. Tap the checkbox to enable the Automatically
adjust clock for daylight savings
time
, if desired
Mar 17, 2010 | Datalogic Falcon 4420 Handheld Barcode...
My acer Extensa 4420 not booting up
dell inspiron 6000 pc note book or
acer Extensa 4420 which one ? either or sounds like hard drive is shorting out and you need to change it  lala linda
Dec 23, 2009 | Dell Inspiron 6000 Notebook
Printer offline mode
plz try by with new cable, if the problem is not solved then check your port
Nov 12, 2009 | Panasonic KX-P1150 Matrix Printer
Ink wont transfer to sticker on a 4420 intermec
Make sure the "carbon" is down so that it gets transfer to the top of the label. I can check this by just scratching it with your fingernail and it should rub off. If you are sure you have the media loaded correctly and the ribbon and label are a compatible match then you might just need to increase the heat or darkness setting on the printer. Some ribbons require a higher heat setting to transfer the carbon.
Jun 27, 2009 | Intermec EasyCoder 4420 Thermal Label...
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
Setup download program for zoom g 4420
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
May 03, 2008 | Zoom 4420 (44200000) 802.11g/b Wireless...
Panasonic KX-P4420 Laser Printer Logo
140 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
