Question about HP Photosmart C6180 All-In-One InkJet Printer
No more black printing, ink cart not empty (80% full).
What cause lose of new ink on aligning cartridges.
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Brother MFC 3240 wont print when 1 ink is empty
Nov 24, 2008 | Brother MFC3240 Multifunction InkJet...
Brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Oct 31, 2008 | Brother MFC-465CN InkJet Printer
I have a Brothers MFC 440CN . My Magenta ink cartridge is empty , how can I get the machine to print in black only ?
If you look at your printers software, there may be an option to "Print greyscale" or Print B & W Only.
Aug 14, 2008 | Office Equipment & Supplies
Cyan ink was full - now it's empty a day later?
Aug 04, 2008 | Brother MultiFunction Center MFC-440CN...
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Printing Problem
Cleaning cycles use ink. So it's no wonder it got worse, the ink level went down. Are you 100% sure that the black cart is full? they can give a wrong reading on occasion. what makes you think its full? Could be also that you need to replace the head- the part the cart fits into. generally they don't last more than 18 months.] Another possibility is that the black is indeed full, but dry. Put a wet sponge to the nozzle, see if it soaks up a decent amount of ink. Good luck
Jun 06, 2006 | Canon PIXMA iP4000 InkJet Photo Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
