Question about Yamaha RX-V461 AV Receiver
No voice i cant listen voice from front left and front right speakers
    President:
  • Yamaha Master
  • 1,114 Answers
Check your "main menu" settings. If you are not using a center channel you need to go into "speaker settings" toggle to "center channel" and select "none" If that's not what your question is, post a comment with some more detail and I will gladly help you more. Hope this helps.
Posted on Sep 05, 2009
All the speaker outlets seem to work fine, except the fronts, all will work, but if i plug the fronts in, all the sound then tends to just fade away, and then i have nothing, no sound. i can't figure...
I would:
1- First make sure you are properly testing using a reliable source, such as a CD Player or itunes. 2- Make sure the Listening Preset is not on Dolby Pro Logic. Make sure it is on Stereo mode and see if the problem persists.
What usually happens is that when listening to 2ch (Left and Right) Audio such as Television or Music and Dolby Pro Logic is on as a preset, Dolby Pro Logic analyzes both Stereo tracks, tries to detect the voices (center channel), ambient sounds (surround and fronts) and processes the signals into a 5.1 or 6.1 System. You tend to get a fading effect when Dolby Pro Logic is selected and listening to an old VHS, DVD or even music.
To remove a preset, make sure you select the Stereo button at the bottom left of the remote to pan through the options.
Hope this helps
Jul 21, 2011 | Harman Kardon AVR 230 6.1 Channels...
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Cant find color codes for my 2003 nissan frontier
2003 Nissan Frontier Truck Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray or Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Jan 09, 2010 | Dual Car Audio & Video
When i call someone they can hear me but i cant hear them what should i do
Hi
first ill suggest if your phone is under warnety then kindly go for support from where you buy, it is much better to utilize your warranty claims on first priority. If your warranty is expire then do the following steps
  1. On the side panel of your phone their is volume key button for increasing or decreasing voice check weather it is not too much low by increasing the volume
  2. you can also check your phone speaker by recording your own voice in , just find this icon in your main menu da6b529.jpg Record your own voice and listen if you are getting your voice clear. or play any ring-tone if your listening any sound from the speaker that mean your speaker is okey.
Note : we often get these problem in mobile communication that we can listen voice of a caller or caller cant able to listen our voice it is because of the disturbance in communication signals, or low signals in high traffic areas.
From all of the above attempts you still not getting any voice from your phone speaker then might be your speaker is not working and you have to replace it , contact authorized samsung hardware support and change your phone speaker .
Thanks
Please Rate !
Sep 06, 2009 | Samsung SGH-G600 Cellular Phone
1 speaker only working. why
I like your thinking...that's just too simple. Nope you must plug the left speaker into the right speaker and pug the power supply into the right speaker. Then plug the right speaker into the GREEN receiver.
That works if you have two speaker..(and/or a sub woofer) it you have four...five...then we use all of those pink, black, white, yellow receivers. But that is a lesson for another day...good luck my friend.
Apr 23, 2009 | Computers & Internet
I cant find the right wires in a 86 toyota 2d hatchback carrolla after I have taken the old stereo out.And I cant find out witch wires go where need help.The stereo tipe is a cxs-gt08hp
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4′
Rear Speakers Location: Side Shelves
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Jan 16, 2009 | Car Audio & Video
No voice audio
Have you selected coax mode with the input button?. If so you may need to play around with the setup buttons. Can't give anymore advice as I've lost my manual. Good luck
Dec 26, 2008 | Sony STR-DE585 Receiver
Audio output
I have the same issue if I connect my digial audio cable from the Yamaha receiver directly to the HDTV. But, I get all 6 speakers working when I connect the Yamaha receiver directly to the Comcast HD box (instead of TV).
Dec 11, 2008 | Yamaha HTR-5650 Receiver
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Can't listen voice when in coming call in
you must take the phone and have it check the speakers may need to be replaced.
Jul 11, 2008 | Sony Ericsson W850i Cellular Phone
Yamaha RX-V461 AV Receiver Logo
81 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
