Question about HP OfficeJet 6110 All-In-One InkJet Printer
Error Message "REmove and Check Cartridge"
I am getting an error message stating that I should remove and check cartridge. I have installed new cartridges, but I still get the error message.
  • 1 more comment
  • Anonymous Jun 10, 2008
    6110 hp printer it says remove and check cartridge
  • gurlyheat916 Feb 14, 2009
    umm i dont know how to say this but i dont have any solution wondering how am i supose to fix this!
  • Anonymous Mar 23, 2009
    I am having the same problem.
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
Error Message
http://www.hp.com/printer/prob676ijt65/solution
818
Posted on Feb 28, 2009
    President:
  • 4,402 Answers
Make sure you took the tape off and are in the correct slot also are these new or refills.
Posted on Dec 08, 2007
2 Suggested Answers
SOURCE: Error Message: Remove and Check Cartridge. Check
Same problem!
What's the sollution without having to buy new cardrigdes?
Posted on Nov 12, 2009
I'm getting an error V150 when trying to use my Pixma MX320 printer it states that I need to check the ink, yet both ink cartridges are full? any idea how to erase this error message? Or does this mean...
Error U150 refers to a cartridge not being recognised. This is due to the refilled cartridge. The machine knows that the cartridge has already been used and is expecting a new one. Some people say that if you hold down the stop key for 3 seconds when powering up it will remove the cartridge check. I have never tried it personally.
Jul 10, 2011 | Canon PIXMA MP180 All-In-One InkJet...
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Same problem!
Nov 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Keep getting a U071 error message for cartge Y
Open the printer cover and check to make sure only one Yellow cartridge is installed. If so, try the following:
Remove each of the other cartridges, one at a time as necessary and see if the error message changes. Start by lifting the cover, then wait for the printhead to move to the left so you can access the cartridges inside. Pull out one of the other cartridges ( not Y) by pushing its front tab back then close the cover. Check the display, repeat as necessary. The error should have changed to U043 (bad or missing cartridge) once you remove the bad cartridge. When you replace it, the printer should work. My guess is the Magenta or Cyan cartridge is causing your error.
Apr 14, 2009 | Canon Office Equipment & Supplies
How can the Error 2200 be fixed? Lexmark X7170
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge.
Mar 31, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Remove and check color cartridge
    the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
    Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    236 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
