Question about Cherokee Jeep Grand CD Changers - 10-Disc
Tire sensor for warning light
My tire pressure warning light came on. My mechanic checked the tires and added air to the back left tire. The light came on again a few days later. Turns out the sensor needed to be replaced. Is this a warranty item? It cost $278 - can I get that back?
  • 3,267 Answers
If the car was originally pre-installed with this type of sensor, then it will be under warranty from that date for a fixed period of time. If this sensor was added later as an additional feature then, this might still be under warranty if offered by the manufacturer will provide service for it's limited time period...........sodeep
Posted on Sep 04, 2009
  • 426 Answers
No its not. they are very sensitive you be careful not to get too close to anything to where it may be hit or it takes em out
The tire light flashes then stays on 2011 Dodge Grand Caravan What could that mean?
Diane, it is sensing low air pressure in one of the tires, or faulty sensor. check air pressure in tire and fill to specification.
Check the attached links for more info,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why Is My TPMS Light Flashing It Could Be Time for New Sensor Kal Tire
Dodge Chrysler Jeep Fiat TPMS Tire Pressure Monitoring System Relearn...
http://forum.chryslerminivan.net/showthread.php/15281-Tire-Inflate-Light-Comes-on
Tire Pressure Warning Light
Mar 12, 2016 | 2011 Dodge Grand Caravan
Why is tire pressure fault light blinking?
Could be low air,two pound less may light blinking.
Dec 14, 2015 | Cars & Trucks
Warning light appeared on the dash, its red in colour looks like a horse shoe with an exlamation mark in the middke
That is the low tire pressure warning. It can come on for several reasons. It commonly comes on in the fall as temperatures drop, the air in the tires contracts and the pressure drops. Check the air pressure and fill as needed. The tires also all need to be within 4 psi of each other.
Another common cause is that one or more tire sensor needs the battery replaced. This is not generally considered a DYI project because for most cars the tires must be removed from the rims. Finally the sensor can be damaged by hitting a curb or by adding chemicals into the tire used to seal small leaks.
As long as you check your tires visually prior to driving it is usually ok to wait to service the sensor for when you replace or rotate your tires.
Please keep in mind driving on a tire with low pressure can damage the tire, the rim or even cause delamination of the tread and cause an accident. The Firestone recall that involved Ford Explorers several years ago was from driving on tires with low pressure.
Apr 03, 2015 | Cars & Trucks
Warning lights list
Sensor from the flat tire or low tire air pressure is located inside the tire air valve on every tires,you need to check the pressure of your tires ,sometimes low pressure will triger the sensor ,if it didn't solve the problem you need to go to tire shop and tell them to replace the battery.
Aug 25, 2014 | BMW 320 Cars & Trucks
Reset tire pressure warning light on
The thing is you can take of the sensor off they have a sensor on all the tires even the spare and If you won to take it off you look at the tire and behind the tire is a box and when you open that box there is a fuse inside of it you take the fuse out and that will make the sensor quit but you would need to do it for all the tires even the spare
Sep 16, 2013 | 2008 Dodge Grand Caravan
Service tire monitor on what is the problem? how do you reset the system?
TIRE PRESSURE MONITOR SYSTEM
The Tire Pressure Monitor System (TPMS) uses radio and sensor technology to check tire pressure levels. If your vehicle has this feature, sensors are mounted on each tire and wheel assembly, except the spare tire. The TPMS sensors monitor the air pressure in your vehicle's tires and transmit tire pressure readings to a receiver located in the vehicle.
The TPMS is designed to alert the driver, if a low tire pressure condition exists. This system also allows the driver to check tire pressure levels using the Driver Information Center (DIC).
When a low tire pressure condition is detected, the TPMS displays the "CHECK TIRE PRESSURE" warning message on the DIC, and at the same time illuminates the low tire pressure warning symbol.
You may notice, during cooler weather conditions, that the tire pressure monitor light, located on the instrument panel cluster, and the "CHECK TIRE PRESSURE" message will appear when the vehicle is first started and then turn off as you start to drive the vehicle. This could be an early indicator that the tire pressures are getting low and need to be inflated to the proper pressure.
Each tire, including the spare (if provided), should be checked monthly when cold and inflated to the inflation pressure recommended by the vehicle manufacturer on the vehicle placard or tire inflation pressure label. (If your vehicle has tires of a different size than the size indicated on the vehicle placard or tire inflation pressure label, you should determine the proper inflation pressure for those tires.)
As an added safety feature, your vehicle has been equipped with a tire pressure monitoring system (TPMS) that illuminates a low tire pressure telltale when one or more of your tires is significantly under-inflated.
Accordingly, when the low tire pressure telltale illuminates, you should stop and check your tires as soon as possible, and inflate them to the proper pressure. Driving on a significantly under-inflated tire causes the tire to overheat and can lead to tire failure. Under-inflation also reduces fuel efficiency and tire tread life, and may affect the vehicle's handling and stopping ability.
Please note that the TPMS is not a substitute for proper tire maintenance, and it is the driver's responsibility to maintain correct tire pressure, even if under-inflation has not reached the level to trigger illumination of the TPMS low tire pressure telltale.
The "CHECK TIRE PRESSURE" warning message and low tire pressure light (telltale) will appear at each ignition cycle until the tires are inflated to the correct inflation pressure.
The Tire and Loading Information label (tire information placard) shows the size of your vehicle's original tires and the correct inflation pressure for your vehicle's tires when they are cold.
Your vehicle's TPMS can alert you about a low tire pressure condition but it does not replace normal tire maintenance.
NOTICE: Do not use a tire sealant if your vehicle has Tire Pressure Monitors. The liquid sealant can damage the tire pressure monitor sensors.
RESETTING THE TPMS IDENTIFICATION CODES
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. Each tire/wheel position is matched to a sensor, by increasing or decreasing the tire's air pressure. The sensors are matched to the tire/wheel positions in the following order: LF TIRE (left front tire on the driver's side of the vehicle), RF TIRE (right front tire on the passengers side of the vehicle), RR TIRE (right rear tire on the passengers side of the vehicle), and LR TIRE (left rear tire on the driver's side of the vehicle).
You will have one minute to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than one minute, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you will need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to "RUN" with the engine off.
  3. Turn the headlamp switch from "OFF" to the parking lamps setting four times within three seconds. A double horn chirp will sound and the TPMS low tire warning light will begin to flash. The double horn chirp and flashing TPMS warning light indicate that the TPMS matching process has started. The TPMS warning light should continue flashing throughout the matching procedure. The "SERVICE TIRE MONITOR" message will be displayed on the Driver Information Center (DIC).
  4. Start with the driver's side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, then stop and listen for a single horn chirp. The single horn chirp should sound within 15 seconds, confirming that the sensor identification code has been matched to this tire and wheel position. If you do not hear the confirming single horn chirp, you will need to start over with Step 1. To let air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage or a key.
  6. Proceed to the passenger's side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger's side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver's side rear tire, and repeat the procedure in Step 5.
  9. After hearing the confirming horn chirp for the left rear tire, check to see if the TPMS warning light is still flashing. If it is, turn the ignition switch to LOCK to exit the sensor matching process. If the TPMS warning light is not flashing, the five minute time limit has passed and you will need to start the process over beginning with Step 1.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems. The spare tire does not have a TPMS sensor. If you replace one of the road tires with the spare, the "CHECK TIRE PRESSURE" message will be displayed on the DIC screen. This message should go off once you re-install the road tire containing the TPMS sensor. The "SERVICE TIRE MONITOR" message is displayed when the TPMS is malfunctioning. One or more missing or inoperable TPMS sensors will cause the service tire monitor message to be displayed.
Nov 23, 2010 | 2006 GMC Yukon
A warning light came on its kinda shaped like so ( ! ) what does this mean?
SOUND LIKE LOW TIRE PRESSURE WARNING.CHECK TIRE PRESSURE,SHOULD BE 32 PSI.
Nov 20, 2010 | 2003 Kia Rio
2008 Camry 4cyl tire pressure warning light on!!!!!!!!
Hello.
Do you have a full-size spare tire? If so, it too is checked via the Tire Pressure Warning System. Perhaps it is low, this is quite commonly omitted when setting tire pressures. If you have a temporary spare tire, it is not checked. If you have no full-size spare, one of the TWPS sensors may have been damaged by your tire changer. This can happen very easily, if the changer is not careful whilst dis-mounting the tires. A Toyota dealership has a special service tool that will check each of the sensors for output, while on the car. If a sensor is found to be bad, the tester will find it.
Dec 02, 2009 | 2008 Toyota Camry
Low tire pressure light won't go out
It sounds like the sensor inside the tire is may be defective.
Oct 29, 2009 | 2008 Toyota Camry
Tire warning light won't go off
make sure all tires including your spare have tire pressure between 34 and 38 lbs if the tire pressure is not between 34 and 38 the tire light will not go off
Nov 18, 2008 | 2007 Lexus ES 350
Car Audio & Video Logo
79 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
