Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
What is the correct ratio for fuel mix for a ECHO weed trimmer..SRM-210
    Problem Solver:
  • 10 Answers
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
    Sergeant:
  • 164 Answers
50:1
Posted on Sep 04, 2009
SOURCE:
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
Echo srm 225 manual
Smoke generally means you have too much oil to fuel ratio in your mix. Mix per manufacturer 50/1 exactly and try again.
Sep 02, 2014 | Garden
Echo SRM-230 trimmer stalls when you give it more gas. Can get more RPM with choke, but still not enough to use. Trimmer only has 20 hours on it.
empty the fuel tank and refill with the correct oil/ fuel mixture as too much oil blocks the jets Machines do not like any e- mix fuels as the jets are not set for the mix.
Jun 22, 2013 | Echo Garden
How to add line to an echo srm 210 weed trimmer
See pages 27 and 28 of the owners manual here:
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
This certainly explains it better than I can.
Oct 01, 2010 | Echo Garden
Hi I have an Echo GTX 2000 weed eater and I need to know the petrol/oil fuel mix ratio
Daniel;
That mix is 32:1. It makes for harder starting, carbons up pistons, cylinders, and mufflers.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil is 50:1.
You are correct, 50:1 is what Echo recommends.
HTH
Lou
Jan 24, 2010 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Fuel mix and manual for Echo SRM 4000
Go to www.echo-usa.com/pdf/documentation/SRM40005000edi_110107.pdf
Mar 28, 2009 | Echo Garden
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
9,219 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
