Question about Frigidaire ATF6000ES Front Load Washer
My washer is displaying F 03. what does this
My washer is displaying F 03. what does this mean?
    Welcome Back:
    Visited the website for 2 consecutive days.
Mine TOO... & it wont drain!
Posted on Sep 04, 2009
What does code 03 mean on my lg washer wm227hw
Have you checked your LG Washing Machine Manual for a List of Error Codes?
Usually the code is generated by a switch or sensor.
There are several things like water level sense, door closed switches.
Obviously one of these is the cause..... I Know..... But which One!
Mar 03, 2015 | LG Washing Machines
Error 03
water drain problem (check drain hose and pump)
Jul 30, 2009 | Hoover AAA160 Front Load Washer
03 dodge durango trouble code "p done" appeared where the milage is displayed, what does it mean?
"P done" means there are no codes stored. If there were codes you would see P and 4 numbers.
May 27, 2009 | 2003 Dodge Durango
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Diagnostic complete
Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
C:00 - Door Lock
C:01 - Flow Meter, Cold Water Solenoid
C:02 - Dispenser Motor, Dispenser Contacts
C:03 - Hot Water Inlet Valve
C:04 - Motor rotates CW at wash speed
C:05 - Heater & NTC (Heater Sensor)
C:06 - Drain Pump
C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
C:08 - Motor rotates CCW at max. speed.
If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Displays F-03
NTC fault its electronic and needs engineer
But try this for most electronical faults first switch off mains wait 20secs and switch back on this resets most gadgets and gizmos if it doesn't work it was a free try.
Nov 07, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
136 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
