Question about InFocus Proxima Remote Control for DP5800 Multimedia Projector
Our Proxima DP5800 will not turn on with remote
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
First check the main switch located at the rear of the unit next to the power socket.Make sure it's turned on. Next, if the projector turns on with the power button on top of the unit, then the problem is with the remote. Replace batteries to make sure fresh ALKALINE batteries are installed correctly--the batteries must SAY alkaline on them. Ordinary carbon batteries WILL NOT WORK! Check inside the battery compartment for corrosion from a leaked battery. To actually test to see if a remote is working, you will need use of a camcorder with "night shot" or night vision capability. Turn on the camcorder and set it for night vision. From a distance of at least 8-10 feet, aim the remote at the camcorder and press a button...you will see the front of the remote light up as if it were a flashlight! That is the infrared coded light the remote produces to signal the projector.If you don't see any light, the remote is bad and will have to be replaced. If you see light, the receiver on the projector is not functioning correctly and will have to be repaired.
Posted on Sep 08, 2009
Reset lamp timer on proxima dp9250+
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jul 09, 2014 | ASK Proxima Replacement Lamp Projector...
I need a remote control for a Proxima ProAv 9320.
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 23, 2011 | InFocus Proxima Pro AV 9320 Multimedia...
Proxima DT 5800 works but picture is much brighter with the lights out ,what could cause to be not as bright with lights on?
The Proxima DP5800 projector is a small format low powered projector at only 650 lumens (brightness measurement). It simply doesn't have enough lumens to cut through ambient light and display a clean image. It is best used in a dark room.
Also bulb age will play a factor in overall brightness. The lamps for that projector are only rated for 700 hours, and as they near the life expectancy they can lose up to 50% of their lumens.
Mar 09, 2011 | Office Equipment & Supplies
Do you know where I can get a replacement remote for the Proxima Ultra Lite LX-1 projector?
The projector is kinda old but your best bet would be ebay or call projector doctor. I know from time to time they have some old remotes.
Apr 19, 2010 | InFocus Proxima UltraLight SV1 Multimedia...
My proxima turns on for about 3 seconds and turns back off
are any leds blinking on the top? check all if the fans and the lamp. if you see dark spots or bulges in the lamp, replace it. if there is still an issue, replace the ballast.
Jun 26, 2009 | InFocus Proxima UltraLight LS2 Multimedia...
Proxima ds1 not lighting
hi
replace or clean the Air filters. Run the lamp reset command if you have.if not solved then check ballast unit which ignites the lamp.
try this also, press the poweroff button on the remote control for ten seconds, the lamp will reset to zero, if you run the projector more than 1100 hours earlier.
Viren
Jan 16, 2008 | Office Equipment & Supplies
Hi ask proxima c420
You can either search for the remote on Ebay, or if you go to proxima's homepage and click on the where to buy tab it will tell you all of the reseller's.  www.infocus.com
Dec 17, 2007 | ASK Proxima C420 Multimedia Projector
Proxima DP2000x troubleshootind
Here is the link to the user guide. http://www.askproxima.com/service/c40/downloads/english_dp2000_ug.pdf i am having the same problem please post an anwer if you get one. -jackintosh
Nov 14, 2006 | ASK Proxima Proxima DP2000X Multimedia...
159 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
