Question about Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC-I am trying to connect my pc to my HDTV. I was unsuccessful in using a VGA cable. I adjusted the output to 1280 x 780 x 60, but all I see is static. Help! Do I need a new video graphic card?
  • 596 Answers
Yes, You will a new video card, if possible, one that is PCIe with DVI outputs andor HDMI outputs and as much onboard memory your budget will allow. The standard VGA port on your motherboard can not support the refresh rate of the HDTV thus the static.
Good Luck
C2Solutions
Posted on Sep 04, 2009
I have an Asus ASB100 Motherboard. Can I use it in a dell dimension 4700?
Sure, if it fits and the motherboard connections match your needed connections.
Oct 04, 2011 | Dell Dimension 4700 PC Desktop
Can not make my pc work with dual monitor, one with the DVI and the other one VGA. My PC is a Dell Dimension 4700
You are right,you can not make that work.You need either dvi or vga,on both monitors.You can not mix them,sorry.Check for an empty pci or pcie slot and add another video card.
Aug 24, 2011 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700
Try resetting the BIOS, see if the drive re-detects
  1. Boot to BIOS F2
  2. turn on all 3 lock lights (NUMLOCK, CAPSLOCK< SCROLL LOCK)
  3. Press ALT+E, then ALT+F then ALT +B and system will reboot and re-detect drives
  4. If HDD is not detected, reseat data and power cable connections, try again
  5. if still no go, then HDD has likely failed
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Speaker No Sound
Check to make sure all cables are connected. After this you will need to click on your sound card properties and set it to 5.1. which will allow all the speakers to play.
Please note you will need to have a card that supports 5.1 sound I do not believe the stock card in the Dell supports this feature which could be the problem.
Feb 05, 2010 | Dell Dimension 4700 PC Desktop
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
Sep 02, 2009 | Dell Dimension 3100 PC Desktop
Is this hard drive sata or ide
It is SATA - Serial ATA (DELL Dimension 4700)
Jan 17, 2009 | Dell Dimension 4700 PC Desktop
Hooking up speakers
The speaker output jack is green as indicated on the setup diagram which can be found here: http://support.dell.com/support/edocs/systems/dim4700/en/index.htm as for the speaker cable itself it may or may not be green. The other jacks are for various input/output devices such as mic, aux, etc.
Nov 28, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
186 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
