Question about GE PSC25MSTSS Stainless Steel
Help ! My GE Profile side by side refridgerator model PSC25MSTA SS is almost three years old. This morning the fridge side dispalyed an inside temp of 90 degrees, and three sticks of butter inside had completely melted. Yesterday I notice the ice in the ice dispenser seemed to be melting, however last night the ice was fine. Ive had a similar problem a month ago when the fridge temp displayed 57 degrees and the freezer display showed 32 degrees but later that evening upon returning from work the temps on both side had returned to normal.
  • 56 Answers
SOURCE: GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Posted on Jun 30, 2009
SOURCE: model #PSC25MSTA SS - one year old, never got a
Had a problem similar to this with this frig and the problem was a bad mother board that kept the fans from operating correctly to disperse the temperature. I woould actually get stalagtites forming from the warmer top shelves to the colder lower shelves. Repaire under extended warantee.
Posted on Feb 12, 2010
espressonist
  • 1711 Answers
SOURCE: All the ice in ice
The problem is that the parts no 240 Defrost thermostat - Limits how warm the freezer section can get during the defrost cycle.
Part Number: AP3884317 made by GE
Need to be replaced. This thermostat should have switch off the defrost element is it exist the temperature in freezer department during the defrost in order to avoid the situation you describe but the most important in that the products in your freezer have meld and freeze again and this mean that they are spoiled and not to be eaten since they are very danger for your health.
The above part and also all the other parts of your model can be found to this link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5240560&diagram_id=24782627#d24782627
Posted on Nov 06, 2010
woodchuck789
  • 4070 Answers
SOURCE: freezer temp. set at 0, but only gets down to 12.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Mar 01, 2011
imufo2
  • 3773 Answers
SOURCE: Model PSC25MSTA SS, Freezer is
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click for article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Posted on Jul 24, 2011
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Psc25pssc ss
If it has auto defrost the temp shown will go really high but only for a short while. It sounds like the defrost timer may be faulty if it is defrosting products
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Model #PSC25MSTA SS - one year old, never got a manual with refrigerator, don't know how to lower the temperature. suddenly, ice cream melting; milk sour; push buttons to lower temperatures, does not set a...
Jan 11, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My ge profile psc25msta model's freezer is at 5 degrees and the fridge is 48. HELP!
5 def in freezer is good / look for frost on back for freezer . this would prevent air flow to fresh food side . laso both fans must be going . inside fan may be going to slow ( repl if so. ) clean coils under frig this will cause over run and poor refri. mm
Dec 07, 2009 | Washing Machines
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
GE PSC25MSTSS Stainless Steel Logo
101 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
