My macbook isnt ejecting the cd in the disk drive. it is no longer recognising the disk is present. what do i need to do?
How to eject a cd
A few ways of doing this
1) restart mac and press down the trackpad button after you hear the startup noise
2) if that does not work try opening up disk utility which is located in applications and then in the utilities folder and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your macbook tilt the
macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVDicon1.png drives in all macs are a bit suspect and if your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they should replace it free off charge. Hope this helps.
Apr 30, 2013 | Apple MacBook Pro Laptop Computer with...
Force eject CD from Macbook
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
Hope this helps.
Dec 19, 2011 | Apple MacBook Mac Notebook
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Eject mini cd from macbook
The only to get a mini CD out of your optical drive is to physically remove it from the drive. This means you will have to take the computer apart and then take the optical drive apart to remove the mini CD.
Dec 27, 2010 | Apple MacBook Mac Notebook
I have put a mini Cd into my Mac book and the computer hasnt recognised it and I dont know how to eject it? Kay
What to do is to pick up your macbook and tilt the macbook to the one side, press the eject key and the effect of gravity will allow the DVD to fall out. The MacBook DVD drive is not designed to take mini CDs. Hope this helps.
Sep 28, 2010 | Apple MacBook Mac Notebook
My macbook wont eject the disk in the disk drive.
Turn on your Macbook while holding touchpad button and hold until cdrom spits out cd.
Sep 04, 2009 | Apple MacBook Mac Notebook
My macbook isnt reading any discs.
There seems to be a problem with the superdrives in the MacBooks. I had mine replaced under extended warranty last month. If your Mac is under warranty, bring it in to the Apple store.
Several macbook users in the past have had success with their optical drive reading disks by turning the laptop upside down and then inserting the chosen CD. Might as well give that a try in your situation.
Drives are available online. Let me know if you need instructions on how to r/r the drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My macbook doesn't burn dvd with iDVD program
Hello, this can happen when the DVD's are not recognized by your Macbook, please check in apple menu, about this mac, more info, and cd/dvd player to see what dvd can your mac accept
Mar 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Oct 07, 2007 | Apple MacBook PC Notebook
k24674
