Question about Pioneer DEH-2100 CD Player
At high volume sound shuts off, subs still work
I recently installed this cd player in my car. It came out of another car and was working perfectly. It is hooked to 4 factory speakers and a kicker amp powering a 10" sub. When I turn it up loud (it happens at different loudnesses, but not low) the 4 speakers stop playing but my sub keeps going. I have to shut the head unit off then turn it back on and everything works again. It does this almost constantly. Any ideas?
  • 752 Answers
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Posted on Dec 08, 2007
2 Suggested Answers
  • 138 Answers
SOURCE: Sound shuts off, sub still works
you may have FIE turned on..
Posted on May 12, 2008
Can I install a Memphis kicker amp 1500 wat to a factory CD player in my 2001 Nissan Maxima
Sure if you have the speakers that take the "KICKING"! THe CD player merely provides the signal to the amp. As long as there is no backfeed of the power of the amp you should be OK.
Jan 02, 2013 | Car Audio & Video
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
I have a vw polo 06. Can i hook up a sub plus rear speakers to the factory fitted cd player?
You can use a hi-low converter off your existing speakers. This will give you rca signal wires to run one or more amps, and speakers.
Jun 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
How do you remove DVD stuck in navigation system
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
Apr 26, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
No sound coming from my factory speakers
Hey Eric, I had the same problem with my 2000 GMC Yukon and because of the OnStar connection in these vehicles you must get power to the factory amplifier which can be done by running a relay wire from the blue remote wire or the power antenna wire to either the pink or green wire on the extra pin adapter that you unplugged from the back of the factory unit. Hopefully you have figured this out by now but for future readers this solution should be helpful.
Sep 18, 2006 | Kenwood KDC-X459 CD Player
Pioneer DEH-2100 CD Player Logo
142 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
