Question about Sharp Microwave Ovens
Try to start, no respond, no light digital number...No sound. Already check Electric plug is fine.
  • 736 Answers
Microwave ovens have a unique problem that shows itself once in a while .. they cant afford to put in a transformer thats big enough to handle two cycles of input power that have the same phase.. there is circuitry in there that tries to make sure that doesnt happen .. it remembers the "turn off" phase and makes sure the next time its turned on it uses the opposite phase.. this is to prevent transformer saturation .. this is kinda technical but anyhow its going to mess up once in a while .. the results will often be a tripped main circuit breaker ... you can check this (if the microwave plugs in) by simply plugging in a lamp to the same outlet .. if it lights then the circuit breaker is ok .. if it doesnt then thats your problem .. find your fuse box and look for a circuit breaker that is in a different postition than the rest .. you have to switch that off then back on again to reset it .. if power is ok and it still doesnt work then you may have a blown fuse inside the microwave ... thats not a place you want to be unless you really know what your are doing .. the voltage and current inside is enough to quickly kill ..
if you or someone else knows how to work with this dangerous stuff .. then they would first make sure its unplugged for at least 5 min .. then look for a bad fuse or fusable resister in the low voltage power supply (usually 12 volts) .. that supplies power to the computer and display .. nothing else will work if the computer is not working .. there is also a thermal fuse inside that will trip if the thing gets toooo hot .. that can happen if air flow is blocked or you try to use the oven with nothing in it ...
Posted on Sep 04, 2009
Testimonial: "Am embarass....it is from Fuse box!!!!! Working...Thanks"
Control panel not responding to touch -- NOT in locked mode!
Sounds like you have a shorting membrane keypad, or there any be moisture or grease in the controls.
To remove the controller to check for grease and moisture, see the video here.
We would need your full model number from the tag in the cooking cavity or elsewhere on the oven to help you further, and our advice is free.
Please post a new help request with the full model number.
Jun 09, 2013 | GE Appliances 30" Trivection Built-in...
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Keypad won't work on model number hvm1540dn1ww General Electric microwave. How do I resolve this? I tried unplugging it and plugging it back in but nothing works
usually in this situation there is a problem with the panel just replace it there is a board behind it but iff the buttons dont respond then its most likley just the panel google the model number and you can get the panel
Nov 02, 2012 | Microwave Ovens
I have a Frigidaire Electric smooth top range and oven. when I set turn on the burners they do not light up or get hot. When I try to bake I press the Bake button and set the temperture but the oven never...
HI.CONTROLS MIGHT HAVE BEEN LOOSE.oR LOOSE CONNECTION BETWEEN the control.Check the control connection inside .It might respond but connection has been loose.hope this helps..
Jun 21, 2011 | Frigidaire Microwave Ovens
Pasquini Livia 90 Auto Espresso Machine I suspect the control unit is failing. For some time, when cold, the machine would try to fill, or run water through the brew head when switched on. A few tries and...
It does sound that you have a problem with the control of the system and could also be the sensor.
I read about a thread for pasquini products and It seems that their technical support and parts or accessories are available through this website:
http://www.1st-line.com/machines/home_mod/pasquini/livia.htm
If you would need parts or someone to go to your place and check the unit, visit the website above.
Hope this helps!
Jun 07, 2011 | Microwave Ovens
One month ago I bought a rival 0.9 cu ft digital oven,model rgst902 ,I only use it mainly to warm things up, I was in the process of cooking something for five minutes,when I went to get the food out the...
I have the same model, after 2 days of normal operation it has stopped working. No lights on the dislay at all and the keypad is unresponsive. If you open the door the light comes on and the turntable slowly rotates. Im taking it back.
May 11, 2011 | Rival Microwave Ovens
My General Electric microwave shows RESET on the console but none of the buttons are responding even though i have plugged and unplugged it a couple of times
Good day Sir, here's troubleshooting tips.
Problem: Oven will not start
possible causes: power surge/plug not fully inserted/door not securely closed/start pad not pressed.
Jan 24, 2010 | General Electric Microwave Oven
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
We have a microwave modell MQ9998W, which is not responding, when we press start, it will not activate, clock counts,and light inside works, just will not start, I feel as though there is a fuse or...
Your issue is;
"we have a microwave modell MQ9998W, which is not responding, when we press start, it will not activate, clock counts,and light inside works, just will not start, I feel as though there is a fuse or something which is the problem. The unit is from 1990, if it is something simple i will try to fix , if not guess you know the alternative"
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Thank you for providing a valid model number!
From your description, it sounds as if 1 or all of 3-4 door switches has failed. Using the link supplied above, you can view a page with these switches. The link below shows an exploded view of the service area. Using an ohm meter will help find the faulty switch.
http://www.repairclinic.com/0100_37.asp
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 26, 2008 | Microwave Ovens
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
