Question about Kenmore 22422 Top Load Washer
Kenmore top load will not spin or agitate
I tried the lid switch it seems to be working. I hear a slight humming near by the motor for about 10 seconds then it stops with a small click on its own.
    Problem Solver:
  • 14 Answers
Drive coupler is bad available on ebay or sears appliance parts little bit time consuming but not hard.remove the top agitator by grasping it and pulling up remove the plastic cover and the bolt under it ,remove the agitator. lay the machine on its side (water may leak out) remove the water pump by prying the clips from the top of the pump slide the electrical connector from motor and start capacitor ,move the clamps on the hoses down from tub and slide hoses off .remove the 3 9/19 bolts holing the transmission in place slide it out remove two 5/16 bolts from clips holding motor and slide motor off transmission replace rubber drive coupling ,installation is reverse of removal
Posted on Dec 10, 2007
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Washer not spinning
If you are neither spinning nor agitating and you can hear the motor running (humming or buzzing) the the problem is with the coupling. See the first link below to repair.
If the motor does not run, only fills, no drain, no buzz no hum then the problem is most likely with the lid switch, see the second link.There is video near the bottom of that page showing how to replace it. Let me know if this helps.
Coupling
Lid Switch
May 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer souds like trying to engage but won't
If the motor hums and will not pump out or spin, the motor is bad. It reverses direction and the reverse windings appear to be burned out.
Dec 28, 2009 | Kenmore 22422 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Oct 08, 2009 | Washing Machines
I have a Kenmore 70 series (Mo No 110.20722990) and it will not agitate or spin. The motor is not running when it is supposed to. I hear the hum and the lights slightly dim (as they always did)when it is...
If you've confirmed that the lid switch is good and the motor coupling is intact, it sounds like you have a either bad drive motor, or drive motor switch. If the motor is humming, however, more than likely the switch is working The following link explains how to replace the motor:
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
The part number for the drive motor (which includes the switch) is 3352287. The cheapest place I found it listed was at searspartsdirect.com for about $135.
If you do determine that the switch is bad, the part number is 8529896. The cheapest place I found it listed was pcappliancerepair.com for about $62.
If you have questions, or require additional assistance, please let me know. I hop this helps you.
NOTE: It still may be a good idea to replace the motor coupling while you have the washer apart. The part number is 285753A. Appliancepartspros.com carries it for about $11.
Oct 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a kenmore series 90 and the agitate and spin will not work, you hear a humming noise or maybe a slight grind
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. The humming sound you hear when the lid is closed may just be the timer motor running. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured. I hope this helps you.
If you determine that your lid switch is broken, please let me know and I will provide you with the steps necessary to repair it yourself (simple repair job). I can also give advice on where to purchase a replacement.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
