Question about Lands Phones
Uniden model ex17960 cordless phone-how to turn off ringer
It is a little embarrassing but I can't find a way to turn the ringing volume completely off. it can be turned down but I am unable to shut totally off. Help. Thanks. Stuart
  • 2 more comments
  • pjmd Dec 23, 2007
    how do i turn ringer off
  • Anonymous Dec 30, 2007
    i have the same problem
  • Anonymous Dec 31, 2007
    yes, it's a bit frustrating to want to turn off the ringer... set it to 'ringer off'...and the thing still rings.
    aarrrggghh!!!
  • butterflypm Jun 17, 2008
    you need to keep pressing the down arrow thing until it lights up saying off low high then you just select the one you want
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Posted on May 22, 2007
One Wire
  • 126 Answers
SOURCE: change ringer from lo to hi
Do you know the model #? If so, you can get the owners manual from the the uniden website. Here is a link to the page so you can look for your specific model number. Just click on your model number and it will load the pdf format of the owners manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Jan 26, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Posted on Mar 23, 2008
divatif
  • 39 Answers
SOURCE: how to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
Posted on Mar 17, 2009
  • 84 Answers
SOURCE: uniden 5.8 ghz phone. Can you turn the ringers off and how ?
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
Posted on Mar 24, 2009
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
Need ringer on uniden ex14246
With the phone in standby mode (not talking, not doing something in the menu, etc), press vol-up or vol-down. The phone will sound the different ring tones at different volumes. To turn the ringer off,
select "Ringer Off". When the phone sounds the ring tone and volume you wish to use, press the end key.
Oct 14, 2011 | Uniden 2.4 GHz Cordless Phone System
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Can't figure out how to turn the ringer on our Uniden 6.0
You can increase the ringer volume from the menu ... by the way Uniden DECT 6.0 Cordless phone basically have very low ring volume ,,, try using an extra ringer which is very cheap or you can make your self ... A simple circuit diagram available on http://www.electronics2day.com/index_files/Page790.htm
Nov 18, 2010 | Uniden DECT 6.0 Cordless Telephone...
I just have a question. We have a Uniden 5.8GHz cordless phone. Is there any way to turn the ringer off completely. My elderly mother is living with us and when I'm not home, I would like to be able to...
My phone is a Uniden TCX905 model.
Ringer Volume
Choose from three ringer volume settings (off,
low, and high). With the phone in standby(normal display), use button on center of handset. Press up arrow or down arrow to adjust the ringer volume.
Jan 26, 2010 | Uniden Cordless Phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Ring
On most Uniden phones, just press the Volume up key to turn the ringer back on or turn the volume up, the more times you press the button the louder it will get. Conversely, pressing the down volume button will lower the ringer volume, and on some models eventually turn it off.
Mar 25, 2009 | Uniden Cordless Phone
Uniden 5.8 ghz phone. Can you turn the ringers off and how ?
Dec 10, 2008 | Uniden 5.8GHz Cordless Phone
How to turn on the ringer
Jun 28, 2008 | Uniden Cordless Phone
Lands Phones Logo
1,263 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
