Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
LC-37G4U Power Light Is blinking on front of TV will not power up. Control Modual and TV have been unplugged and re-plugged in after 5 min and still no solution.
  • 1 more comment
  • ryan_grennes Sep 04, 2009
    When I hit the power on the remote the TV power light will stay lit for 4 seconds and then starts to blink red continuously.
    When you say unplug all internal components what do you mean.
    i was told to do a hard reset by unplugging all external and internal components, what internally would i need to unplug? or any other suggestions
  • 11,896 Answers
The power supply should be tested with voltmeter to see if it is working correctly. The capacitors in the power supply nowdays have extremely high failure rates due to cheaper parts.
You can purchase a service manual and a capacitor tester to test
Posted on Sep 04, 2009
  • 10,594 Answers
LC-37G4U seems have either bad power supply or defective back light inverter board that causing no power problem.
In my opinion qualified TV tech is required to identify is it either power supply or back light inverter board by testing output volts of power supply board that goes to back light inverter board (approx 24 DC volt)
I would recommend to download service manual copy for small fee from HERE if you are trying to fix it by yourself and Power Supply and Back Light Inverter boards are available in Shop Jimmy.
Click on above links to get price info.
Thanks.
  • 430 Answers
Have you tried a hard reset. In a hard reset, you have to de-attach every part which is attchable ( internal and external ). This will solve any hardware issue. Also check the internal wiring.
Flashing green power light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link.
Dec 07, 2013 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
SHARP LCD TV LED SLEEP AND TV BLINK I and I can't reset whith vol - and chanel down when i plu ac cord someone have an idea ?
- Unplug the TV and count to 10 slowly.
- Hold down the power button on the TV (not the remote.) ;))))))
- Plug in the TV while holding power button.
- Count to 10 and release the power button.
- Turn it on and hope for the best
Sep 24, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Power light and opc lights blinking green
It can be the power supply is sensing short circuits in the power supply itself or in the backlight inverter board, those are the two areas you need to inspect.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 10, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp TV LC37D40U Aquos malfunction. It fails to turn on (no picture, no sound) except that power button light blinks off and on continuously. Any ideas. Thanks.
The blinking light is a indicator of a internal failure, it usually blinks as an error code, I have two suggestions, unplug the TV from the power outlet and let it set for at least 30 minutes not plugged into the wall outlet, then plug it back in and see if it has returned to factory defaults and returned to normal operation, if that didn't work then contact sharp @ 1-800-237-4277 and they will gladly assist you. Good luck !
Nov 30, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
110 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
