Question about Samsung NV24 HD Digital Camera
Does the rechargable batter go bad? I have a
Does the rechargable batter go bad? I have a Samsun NV24HD. It works fine for a few minutes but then the screen turns into green lines, or everything is distorted. It can not be turned off, or if it does turn off the lens does not retract. I take the battery out and put it back in and then it works for a while. Last night when trying to upload photos to my computer it locked up in the middle of downloading. Then I got an error message on my computer that new hardware could not be found. The camera is less than year old.
    Brigadier General:
  • 11,967 Answers
Yes, rechargeable batteries can go bad. You should try using a separate card reader to download your pictures...solves a lot of problems. Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Sep 04, 2009
Equus #4320 multimeter
well this could be a few things wrong , first does this one have the built in rechargeable batterys ? if so there bad and need replaced , reason numbers counting down slowly . second does rotary selector look damaged or feel "loose" seems you have a bit of a bad connection in the rotary switch on front (could have gotten liquid down inside it too) yooul have to remove back cover (carefully !!) and wash out switch with contact cleaner (care to display window !!)
Aug 13, 2016 | Equus 4320 Digital Multimeter Ul Cul10...
2010 G37 - battery was dead - jumped it off and drove it for twenty minutes. Next morning it wouldn't start and now it wont stop clicking (like a relay). Any suggestions?
if the battery goes dead or low it must be recharged with a charger, driving the car will not recharge it properly. The alternator is only meant to maintain the battery, not recharge it. Get the battery recharged and verified and then try again.
Mar 02, 2015 | 2010 Infiniti G37 Coupe
Car will start but wont restart after running several minutes.
Is your battery any good? A bad battery will not charge or charge properly and be at the root cause of your issue.
Jul 28, 2017 | 1997 Mitsubishi Eclipse
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
Battery and charger not working correctly.
u r charging,but the charging stays for a few minutes,go for a new battery and try
Mar 04, 2010 | Optics
When air con swiched on heat after a few minutes it closes and the figures e4 and 58 come on. product is aqv12v
E4 meaning high discharge temperature or pressure. Not able to find 58 but I know it also is a refrigerant issue dealing with pressure. Have a tech come in nd do the following:
Normally in cases like this your best option is to reclaim the system, pull a deep vacuum on it and then recharge it with fresh refrigerant by weight as per the manufacturer's recommendations.
Jan 15, 2010 | Samsung Heating & Cooling
Uniden cordless handsets don't hold charge
Have you tried replacing the batterys with new rechargables? if not open up the back and replace old batterys with new ones, just see if it works with a normal non rechargable batterys if it does buy some new rechargable, other than that your base i.e. charger may be faulty most likely it is the batterys.
Jul 19, 2009 | Uniden Cordless Phone
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Samsung NV24 HD Digital Camera Logo
88 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
