Question about Cuisinart Private Reserve CWC-900 Wine Cooler
Cuisinart wine cellar CWC-900 "Both fans are dead"
Dead fans where can I buy them?
Brushless DC Fan
TD9025HS
DC12V 3.36W
DC Brushless Fan
Model: DFC601012L
DC 12V 0.08A
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
My power supply keep on blowing fuse. I tried replacing fuse twice and immediately blown when plugin power. What could be the reason?
A dead short is more than likely. Potentially a shorted out compressor or wire pinched or a bad control board. I'd check the compressor terminals to ground, any motors to ground. With and without the wires hooked up to them. If the compressor or fan motors are grounded out it could cause that symptom. If you test them with the wires hooked up it will tell you if the wiring is shorted to ground.
Mar 24, 2016 | Cuisinart Cwc-1600 16-bottle Wine Cellar...
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
The unit is completely dead. no lights and no fan. Both fuses on the board are good.
If it is dead, and doing nothing at all, have you checked to make sure its not a power failure to the unit? Sounds to me that may be a problem if all is dead. You probably checked this first, but make sure. I repair wine coolers, walk-in boxes on a day to day basis, and if you have no lights or fan, and nothing at all is coming on, it is either a power failure coming in or the power cord its self has come loose to the control section. That's all it could be, you have lost power. Check for power at the board if you have power to the outlet. The reason I believe you have no power to the unit is you say the light and the fan are off, and nothing is working. Please check and let me know.
Sincerely,
Shastalaker7
A/C, & Refrigeration Contractor
Jun 07, 2011 | Cuisinart CWC-1200 Wine Cooler
How do i get the cabinet off to get to the fans on a cwc 900
You'll have to drill out the little plastic tabs which hide the star screws. I used a Dremel and a quick tap on each little tab to make a small hole, then pried out the plug. Then use a star tool (T10) to remove screws. The fans get dusty and sieze up. Lousy assembly to keep clean, but will be easier now. I had to replace the larger fan.
Nov 24, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Unit will not cool. Stays at room temp.
based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Jul 31, 2009 | Cuisinart Private Reserve CWC-900 Wine...
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I also had one of these CWC 900 units that quit working. The interior temp was 77deg F and the outside was 70 deg F.
The exterior panel was very warm to the touch where the heat exchanger was.
Like a previous person stated, there are two fans. One on the control unit board and then the main cooling fan for the exchanger. In my case, this main cooling fan had quit working - allowing excess heat to build up.
Solution: Unplug the unit! Remove the side panel of the CWC 900. First remove the 8 "finishing" plastic plugs that hide the screws. This was done with a sharp point on an ice pick to pry them out. Then remove the 8 screws with a torx T10 driver. At this point, plug the unit in and lower the temperature setting. In my case the small fan kicked on and the larger one did not. Un plug the unit. If you try and manually turn the fa you will feel resistance. Remove the cooling fan and black housing w/ 4 phillips screws. seperate the wires from the cable ties and then unplug the fan - you may have to remove a small amount of a plastic type glue to unplug the fan. Remove the fan from the plastic housing w/ 2 phillips screws. This is a fan made in China and I was unable to find a replacement on the web. Remove the center sticker on the back with the fan model number. Remove the center black plastic plug with a sharp point. You will now see the end of the shaft and a small split keeper ring. This ring is made of plastic - be gentle. Pry it open and remove it from the shaft (KEEP IT). Once the keeper is removed, you will be able to pull and seperate the motor from the fan blade and expose the shaft. I was not able to remove the small bearing from the motor so I wipe the shaft clean, applied white lithium grease and the re-assembled the unit. Fan spun freely. Put everything back together and the unit should be fixed!
Hoped this helped.
Mar 19, 2008 | Refrigerators
Cuisinart Private Reserve CWC-900 Wine Cooler Logo
2,696 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
