Question about Maytag Washing Machines
Maytag washer LAT9706AAE rapidly leakes water that drains to the backside. What needs to be done to correct this flood.
  • 5,081 Answers
Try opening the washer door and feel all the way around the inside of the door seal for any rips or perished areas , if this is the cause the water will leak out from the front behind the panel .
If you think it is leaking from the back it could be several things such as the pump ,the pump hose , the outer drum , or even the bearing housing if it is whining when spinning fast .
You can see everything that's going on in your maytag washer by pulling off the front panel. There are 2 screws near the bottom holding the front panel onto the frame. Remove these screws and pull the front panel off. Just run a wash cycle and see where the water is coming from if you can.
Sounds like That is your drain pump. You will just need to replace it. When water leaked out that tiny little hole on the side of the pump it means that the bearings are going out--- but this should almost continuously leak throughout the cycle not just during spin.
Posted on Sep 04, 2009
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Maytag turns on but won't aggitate
ahh sounds like the maytag drain pump, it seizes up and over heats the motor. look for belt under unit, pump is front right or rear right. buy the pump asm. They sell a pump by itself but you want the assembly at the same price, its a newer design
Jul 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washing Machine Model LAT9706AAE Won't
Check at the back of it,the rubber belt may have become loose or sometimes slips off it course and may need re-fixing....
Jun 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
NO HOT WATER MAYTAG WASHER Model # LAT9706AAE
replace the dual inlet valve located in the rear of the machine. have included a link to help you...you can also purchase the part from the same link. http://www.partselect.com/repair.aspx?appliance=washer&part=replace-water-valve
Jun 22, 2009 | Washing Machines
Front loading Maytag Neptune doesnt drain all water
Remove the pump and clean it out. Access the pump from the rear.
May 25, 2009 | Maytag Washing Machines
Won't spin after drain seems it has rough spot
Its the water pump- a shiney metal retainer is partially out and rubbing against its housing.
Mar 29, 2009 | Maytag HAV3460AWW Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
