What does f05 mean
My hotpoint wt965 has flashed f 05 what does this mean
please help
  • 15,935 Answers
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint aquarius is not spinning or draining..f-05 is flashing on and off...
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean filter inide hose.
Refit and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
My hotpoint keeps flashing up f-05
Remove large black hose onto bottom of drum.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Hope this helps you with your problem.
Nov 29, 2009 | Washing Machines
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
