Question about Toshiba (K000019660) Motherboard
Not getting the 3.0vdc i need from the main boardto power the inverter.
  • rnnielsen Sep 04, 2009
    Do you mean the cap marked with black, can you give me a resistor number?
  • rnnielsen Sep 05, 2009
    Not getting the 3.0vdc i need from the main board to power the inverter that controls the screens back light
    This is on a Toshiba laptop mother board # k000019660 I have 2 board with this problem.
    Thanks
  • 11,896 Answers
FIRST THING you should do is buy a new motherboard cmos battery. If that doesn't work or your time is not correct, then you will want to
unplug the power supply, after turning the thing off of course.
Then short out the CMOS jumper pins. Most boards have a way of shorting out the CMOS. It clears the CMOS which is related to the clock some how. It does not affect the battery. The shorting out process is very quick, like less than ten seconds should do it.
Then normalize the CMOS jumper to its original working position and the CMOS clock should start running, this time for good. Yes, go through the start up procedures.
I don't think you have any complex issues, but one never knows. You'll of course have to reset your cmos entries, including the clock, to what you want them to be.
So, I recommend looking at your boards manual and search for "clearing the CMOS" information.
Posted on Sep 05, 2009
    President:
  • 1,462 Answers
It seemd that your power cupply unit ie, SMPS unit has been damaged, try replacing the power unit to get proper 3.0 vdv voltage, This is the only solution for this,.. If you are electronic expert try trplacing the 10ohm resister situted near 9 big black capacitor, this shoild solve your problrm
Vinod Kumar RNJ
Posted on Sep 04, 2009
  • Vinod Kumar
    Vinod Kumar Sep 04, 2009
    Yes the one with the black one....
  • Vinod Kumar
    Just search for 10ohm resistir, there may be only 2/3 10 ohm resistor, you can identify by blackened heated form
I have an LG 55 inch tv (55LA6205-UA). I have sound, but my picture goes out. I did the flashlight test and can still see an image on the screen. I do not know which board to replace.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 16, 2017 | LG Televison & Video
What would cause a black screen on vizio LCD Tv? I have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 14, 2017 | Vizio Televison & Video
LG tv 55GA6400 has sound but picture keeps going black after a minute or so.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | LG Televison & Video
Vizio tv 37" picture started to get darker
Jan 11, 2017 | Vizio Televison & Video
What is wrong with my TV? No picture but has sound. picture shows with flashlight.
Jan 08, 2017 | Televison & Video
Get red LED and power up sound but only black screen. Am curious as to is it power board or main board??
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Oct 12, 2016 | Samsung Televison & Video
Is the Backlight inverter and the power supply unit in the same board for this tv?
May 18, 2016 | Televison & Video
I have a samsung tv un46eh500 with sound and a dark image...is it backlights?
May 10, 2016 | Samsung Televison & Video
Computers & Internet Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
