Question about Haier 45-Pint Dehumidifier
I have a model HD-306 Haier dehumidifier which is hooked up with a hose to a drain. It has been working fine until several days ago. Water now is coming from the bottom of the unit onto the floor. I removed the hose and took out the bucket and everything looks ok. The hose was not clogged. Why is water now coming from outside of the unit?
  • 128 Answers
Please make sure the unit is leveled.also make sure the hole in the drain pan not clogged.also the size of the hose must be fit the hole not smaller
Posted on Sep 13, 2009
Model DM32M Haier Dehumidifier. I am missing a part which diverts the water into the hose drain. All the water now goes directly into the bucket. I want it to drain into the sink nearby.
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Sep 22, 2017 | Haier Dehumidifiers
Haier HDN655E - water does not drain out of hose
check the hose connection,when new these units have a knock-out plug where the hose goes so if your only going to use the bucket and not the hose it wont run out the hose connection
Aug 01, 2010 | Haier HDN655E Dehumidifier
I have a Maytag model M7DH65B2A dehumidifier that has worked well for several years. However, when I hook up the hose to drain off the water when we go on vacation the water still fills up the built-in...
Hi Graham. Check the hose and the opening to the hose through the base of the dehumidifer. There is probably some debris in there causing this aggravating problem. J.
Jul 31, 2010 | Maytag M7DH65B2A Dehumidifier
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 05, 2008 | Haier HDN655E Dehumidifier
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Haier 45-Pint Dehumidifier Logo
262 people viewed this question
Top Haier Dehumidifiers Experts
greg54308
Level 1 Expert
Mike Kolbay
Level 1 Expert
Bill Long
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
