Hi there i have a cagiva mito 125 lucky explorer 91 plate got teh bike started up fine on electric starter but riding bak i stopped and bike cut out electric start had failed so had to bump it howevere if you hard wire the starte it goes ansd if u bypass the relay it works does this mean i need a new starter relay
SOURCE: Starting problem
You probably need to add water to the battery or the battery is getting weak and needs to be replaced. Water should cover the top of the battery plates. Get a 1 or 2 amp trickle charger and charge the battery for a few hours.
The problem may now go away.
If it continues then put a volt ohm meter on the battery and see what voltage is present when revving the engine. The voltage should be about 2 volts higher than the listed battery voltage, as in 6v now 8v / 12v now 14v.
If not, have the dealer check the stator and rectifier/regulator.
Please rate this solution. (four diamonds would be nice) Thanks!
SOURCE: I want to buy 1990 aprilia af1 futura...is it
It has the same engine with Mitto but that engine is more fragile than that of the CBR's.
Don't buy it if you ask me.
SOURCE: i want a manual for cagiva mito 125 year model
Go to, http://www.mmra.org.uk/marci/mito/
should be able to download the 1 you want
SOURCE: clicks whenever i hit the electric start
I made this a problem with my bike after a rebuild! Turned out to be a screw on the front starter relay right at the front (cross headed screw) wasnt fully screwed in, hence causing a bad earth and causing the clicking sound to appear to be coming from the relay switch under the seat.
You want to gurantee that it is an earth problem?? Try hitting the subframe with a metal spanner or flicking the footpegs up and down.. youll find it then starts first time!
Peace
