Question about Ruud Central System Air Conditioner
Turned on a/c unit no air blowing from vents. unit is on out side runing
  • 534 Answers
2 things could be the problem 1 The blower motor capacitor has one out. This is a small oval or round piece that the wiring to the blower motor is attached if this is out the blower motor will not work. 2nd. the blower motor itself has burnt out. Replace the capacitor and the motor together should you have to change out the motor. Good luck hope this helps
Dave
Posted on Sep 04, 2009
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
Unit freezies ,blow does not blow sometimes
Your unit was run without filters in place and the coil has a dirt/fuzz coating that gets wet from condensation and then freezes when unit is on. When this happens less and less cold air comes out of vents making unit run continuously . The fix. Turn the AC off and run fan only until air flow returns to normal and air is warm. Then carefully remove debris from return air coil on the air filter side
Oct 22, 2015 | Heating & Cooling
I have a RUUD gas pack unit.....when you turn on the heat, the blower does not blow any air out of the vents while on "auto". If you put it on "on" it blows cold air out of the vents. What is wrong?
Sounds like the thermostat is hooked up wrong. If the ac doesnt work right its in the thermostat programming or the wiring. Hope this helps good luck
Jan 13, 2013 | Ruud UAMB Air Conditioner
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My inside air conditioner fan isnt turning on whats wrong?
If the in side blower motor turns off with the out side unit normal operation if the thermostat in the auto position set for cooling If the out side unit run with out the in side unit the out side unit will be wrecked . sounds like you need service and have it cleaned for best performance . Tom
Jun 17, 2009 | Heating & Cooling
AC unit outside turns on but no air blows through the vents
Your indoor unit pc board is bad, replace it.
May 08, 2009 | Heating & Cooling
Passenger side blows hot air when front control set to Air
you cant adjust it ,this requires the dealers computer to re set it,or a phyiscal control has packed up like a vacumn pipe has split where it pushes onto the valve that controls the flap in the heater unit.
Apr 25, 2009 | 2005 Dodge Durango
2002 New VW Beetle is only blowing hot air out of vents even when set on cool. I was driving and I made a turn at an intersection and all of a sudden the cool vent air turned to hot air like I had the heat...
On the bottom of the air unit is the lever that changes temps. It likes to fall out of place.I propped mine back with a piece of half-inch copper pipe a couple of years ago.Remove glove box then panel on front side of console to access.
Apr 09, 2009 | 2003 Nissan Altima
Ruud Central System Air Conditioner Logo
190 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
