Question about Hotpoint Aquarius WMA42 Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
  • simmonds8 Sep 05, 2009
    Thanks Barkencoa, I followed this up to remove the bearings - that bit seems to be impossible!! One of them fell apart but left the outer casing firmly wedged and the other is fixed solid in the outer drum. I now have an interesting array of bits on my kitchen floor so need to decide my next move. Any ideas how to remove the bearings from the drum??
  • Hotpoint Master
  • 3,463 Answers
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Posted on Sep 04, 2009
Testimonial: "Your solution answered my question, but left me with another. How to remove the bearings from the drum. "
  • Barry Coates
    Barry Coates Sep 08, 2009
    Your best solution is to replace tbhe whole tub assy as a complete unit, only way to guarantee a satiusfactory repair.
How to remove beayring
Posted on Apr 21, 2014
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
Change hotpoint wmd 962 g uk drum bearing
Hotpoint dont sell the bearing for WMD962 seperately. You have to replace the whole drum unit.
Dec 01, 2012 | Washing Machines
Is it possible to change the drum bearings on a Hotpoint WF860 washing machine??
it is possible but not a job that could be called easy, you have to completely dismantle the machine to remove the inner drum and then the bearings. It all depends on your level of mechanical ability but will be a job that takes you a few hours at least.
Mar 02, 2012 | Hotpoint Washing Machines
I am looking for an instruction manual for a Hotpoint Aquarius 1200 WM64 and I can not find one online to download. Can you help?
Hi.
Please click on the link below to open the owners manual for Hotpoint Aquarius 1200 VM64 in PDF format:
Hotmpoint WM64- Washing Machine
Regards.
Ginko
Sep 13, 2011 | Hotpoint Washing Machines
Need to change bearings
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
May 07, 2010 | Hotpoint WMA64 Front Load Washer
Removing transmission top bearing
For all your parts visit our sitehttp://www.apart4u.co.uk
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
Mar 29, 2009 | Hotpoint VBSR3100D Top Load Washer
Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Sep 27, 2008 | Hotpoint Washing Machines
Hotpoint wm80 bearing replacement!!
The drum will have to be removed.
Bearing replacement on ANY Hoover can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Hoover washers require at least 2 specialized tools for removing certain components of the machine.
Jun 26, 2008 | Hotpoint Washing Machines
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Changing rear drum
I presume you mean the inner drum, this is major strip down, remove the top, remove the front panel and the control panel, remove and split the out drum in half, remove the drum pully, refit the nut and hit the spindle with a hammer using the nut to protect the thread, this will force the drum spider out of the bearings, reverse the process to reassemble. Regards and good luck Advisor
Sep 01, 2007 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
1,192 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
