Question about Philips Magnavox MWR10D6 DVD Recorder
Using both MWR10D6 & MWD7006 Remote control controls both, how to fix?
My recorder and player are set up so that one is on top of the other. When trying to use one, the other responds. How can I change the codes on the remote control so that I can control each one separately? It is not feasible to physically separate them.
  • Lee Todd Dec 10, 2007
    Thanks for your answer. I guess I should have told you that we are trying to use the machines to record our home DVDs from the player to the recorder. We have made movies of our GrandDaughter's graduation and are trying to duplicate them.
    Therefore, we need to use both machines at the same time. Ugh, I guess there is only one solution, get a different manufacturer's machine, so the remotes won't operate both of them.
Remote controls use infrared beams to control their components.  Since infrared is limited to line-of-site, simply blocking the receiving window on one or the other component will keep it from getting the remote's signal.  Just put a piece of paper or cardboard in front of one of the components.  Activate it with the remote and then move the paper/cardboard in front of that component and activate the other.  Not the most elegant solution, but it might get you what you need.
Posted on Jan 04, 2008
Make a cover out of card stock and tape it over the top machine when you don't want to use it just flip the cover down over the front where the sensor is.
Posted on Dec 10, 2007
I need the 4 digit code for Magnavox dvd player mwd7006?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
May 01, 2016 | Magnavox MWD7006 DVD Player
Cannot set anything with the remote
Tries to clean out the batteries compartment like metal - + battery connections with a rag with some WD40 chemical to get rid of the rust and dries condent moisture.Wait like another 10-15 mins for the effect to take place,replace the remote with a new set of battery,it should be working again.If it still have the same problems,the remote control CPU chip it is dead,the remotes devices it is heavily dependent on it CPU chip.Try website like to buy another remote same as the original or very close compatible to the original remote.
May 23, 2011 | Philips Magnavox MWR10D6 DVD Recorder
I need a manual for Magnavox dvd/ recorder for MWR10D6
Although this is a Magnavox DVR, it is made by Funai. The manual for it can be found at:
Hope this helps!
Jan 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Dvd player
Are you using a DVD+RW disk? Unlike DVD-R, DVD+R and DVD-RW disks you cannot finalize DVD+RW disks on the Magnavox MWR10D6 DVD Recorder. Instead you have to make the disk compatable [Make Edits Compatible], this allows you to close the disk and play it on other DVD players.
go to: Setup ==> Edit Disk ==> Make Edits Compatible ==> Yes
Other than this nothing else comes to mind to troubleshoot this problem. Hope this helps.
Aug 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Lost Remote Control
wal mart sells a phillips universal plip remote that works with the unit but the code for the dvd player is not listed so you have to do a manual code serch pain in the !@# but other then that it works
May 29, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Recorded disc playback trouble
You have to finalize the dvd's through the menu... from page 36 of the manual....on the remote control press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK.
Jan 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
309 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
