I have a phillips 42'' lcd tv and was told that i need to replace my ssb board and it would cost 500 dollars. how can i fix this myself if i buy the part
  • 157 Answers
Ssb board should be available thru tristate module or pts electronics-if you give them the model number they can give you the price
Posted on Sep 04, 2009
My Phillips Big Screen TV is having audio problems I cannot hear anything but the picture is still great. Do you have an solution to resolve my issue?.
I would certainly challenge the fact that your SSB is bad. This SSB is known as the the small signal board. This board is a little larger than a credit card and is seated on top of the signal module( The board with all the RCA jacks and RF connections). It is located inside the TV on the left side of the rear of the TV. I must caution you, the replacement board will exceed any expectations you may have for repair. The cost of this SSB will be near $300 dollars. Then you will need a TV tech to enter the software to correct geometry. This SSB controls the screen size and colors (gray scale) and sound, etc. Sorry to lay the hard core facts. But it will not be feasible to repair this aging TV. I have seen and repaired many of these when they were under warranty! Thanks for asking and show all hands of support.
May 13, 2011 | Philips 60PW9363 60" Rear Projection...
Have you heard of the 'Y Sustain' part?
YSus board is common cause for this kind of problem, if a tech told you that you need to replace it, probably you need to.
Oct 06, 2008 | Philips TV Tuner Video Capture PCI Card -...
My Sony Bravia KLV26S400A has been giving me problems lately. It works normal initally and after a while it shuts itself off and the \"Timer/Standby\" light blinks 8 times. Any idea what the problem is?...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Capacitors are very inexpensive. Less than a dollar a piece.
Hope this helps
Aug 03, 2010 | Sony KLV-26S400A LCD TV
How do i replace an ssb board on a 42" phillips lcd flat screen. Can I do it myself.
This depends on the set,sometimes you need the have Compair to install some software.
If you have a complete panel from a scratched unit it's easy to replace it yourself.
Sep 04, 2009 | Televison & Video
LG 50px1d parts instillation
buy a new TV you can GET a TV with the same SPECS. for $500 to $800 Dollars depending on sales so don,t waste your money besides to plasma panel life is only good for five years(24/7) on this model. I have a similar situation and now after reading these post it is just not worth putting money in......
Jun 25, 2009 | LG 50PX1D 50 in. Plasma Television
LG 42 LCD no sound or picture
This is probably bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Jan 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Lg 42" hd 1080p
This could be bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Manual
You will losse time to fix your tv,good way change that boards, i get 500$ fo r fix it.contact with me by email : nhonhang1@yahoo.com
Sep 10, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Lcd tv no picture
This sounds like a bad PC board. Your last resort is to pull the plug and plug in after 1 minute, and hope this resets the main board. It cannot be home serviced if you do not have the right spare parts.
Aug 21, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
