Question about Cosco Eddie Bauer Musical Rocking
Sheets for eddie bauer bassinet
Where do I get sheets that fit the mattress that comes with the eddie bauer bassinet?
Need battery cover for Eddie Bauer musical rocking bassinet model # 10330
looking for a battery cover for bassinet model #10330. Where can i get it?
Thanks
Apr 10, 2014 | Eddie Bauer Musical Rocking Bassinet...
Dont know how to remove the bedding from the bassinet to wash
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
When the baby lays down on it the mattress part leans to to side.
If this is the Bassinet that rocks, there should be a set of locking slides at the top
where the bolts run thru connecting the bassinet to the frame. Slide the locks into
the groves and the bassinet should remain centered. If it is a different model please advise.
Mar 12, 2011 | Eddie Bauer Baby Gear
I need the mattress that fits this crib. Any help on where to look?
You can try checking out amazon.com or landofnod.com for the crib mattress that you need. Make sure you know the dimensions of the bassinet you are looking for. You can find the features and the description when buying.
Also check Eddie Bauer list of products to find out if they offer spare bassinet mattresses for their cribs.
Source: http://www.bestmattressreviews.com
Feb 15, 2011 | Eddie Bauer Musical Rocking Bassinet...
I have this Eddie Bauer Musical Rocking Bassinet, but I am not real comfortable with the mattress part. It seems too cushy, like the babies head would sink right into it if our baby was ever put on his or...
for one thing you dont put a new born on its tummy.you just move the head left to right to stop flat heads accuring.if you have other concerns try looking for a materess at a locol store. one thing you could try is wool materes protector it kind of firms the materes up alittle bit.
May 23, 2010 | Eddie Bauer Musical Rocking Bassinet...
Where can i find the bedding for the eddie bauer bassinet? i only have the bassinet not the bedding.
Most baby stores (Babies R Us, BuyBuy Baby, Toys R Us, etc) carry bassinet sheets. They have elastic edges so they fit most sizes. I found that for my granddaughters abssinet, there were few color choices so I used pillowcases and tucked the excess under the mattress. Other than that, if you want something made specifically for your brand, generally you'll need to contact the manufacturer or make it yourself.
Apr 21, 2010 | Eddie Bauer Musical Rocking Bassinet...
No manual for eddie bauer complete play yard
I found the instructions in a pocket on the bottom of the mattress they provided. Might take a look there
Sep 14, 2009 | Eddie Bauer Baby Gear
Bedding
There are so many sites like ebay, amazon etc.
I am attaching link for one of the site s:-
http://www.amazon.com/Eddie-Bauer-Musical-Rocking-Bassinet/dp/B000132W02
Thanks.
Jun 04, 2009 | Eddie Bauer Musical Rocking Bassinet...
Cosco Eddie Bauer Musical Rocking Logo
217 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
