Question about LG VOYAGER VX10000 Cellular Phone
My alarm is not working - LG VOYAGER VX10000 Cellular Phone
    President:
  • 1,884 Answers
Are you getting soung otherwise. Yes I suppose otherwise you would have mentioned in your complaint. It could be tha your firmware dealing with alarm has got corrupted and needs reinstallation. Do that. Before that backup your data, both from the phone memory and the memory card to youe PC and remove the card from the phone. Or better still get the firmware reinstalled from LG Service Center. That would ensure that whatever viruses it may have will also be overwritten.
Posted on Sep 11, 2009
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Jan 20, 2013 | Watches
Car alarm indicate led stay on all the time, although the lock and unlock work its a gm vsc3100 alarm system. Any help will be appreciate. Thanks
This is the aftermarket alarm may be time for a new set but before you go that direction the alarm light may have shorted to a power and not affecting the alarm itself by the way does the alarm horn work and is it diconnected because if it is it realy activated. If it isnt and alarm horn works but the light always stays on the the alrm internal relays doesnt switch over. The fix most area will make you get a whole new one
Apr 21, 2011 | Chevrolet S 10 Cars & Trucks
2002 jeep grand cherokee , alarm won't work ,near side mirror does'nt operate , near side windows don't work ,no central locking.
My Car Alarm Won't Work By HilaryPost, eHow Contributor updated: October 10, 2010 car-alarm-won_t-work-200x200.jpg Troubleshooting a car alarm problem doesn't have to be hard. Fotolia.com">car keys image by bright from Fotolia.com
Troubleshooting a car alarm is relatively easy. You don't even need any tools or manuals to figure out what's wrong. Though car alarms are meant to protect the safety of your car, they can sometimes provide problems of their own. With these simple steps, you can find out what the issue is and attempt to fix it. Common car alarm issues include: your alarm not working, your alarm going off at inappropriate times and your alarm failing to activate itself. You can solve your car alarm's problems by following these easy troubleshooting steps.
Difficulty: Moderately Easy Instructions
  1. 1
    Do a routine check of all your car's systems. Sometimes, other parts of the car are causing the problem. Don't assume it's your car alarm before a thorough check. For instance, if you car will not start, there is probably something wrong with your battery or starter.
  2. 2
    Disable your alarm manually. You may have to set the alarm to valet mode while you diagnose the problem. To do this, put the key in the ignition and press down on the push key until the light on the switch stays a solid color.
  3. 3
    Check your sensors. Sometimes your car alarm will go off at inappropriate times if your sensor is too sensitive. Just adjust your settings to fix the problem.
  4. 4
    Turn off or disconnect any other devices you have in your car. Often, radar detectors, GPS devices and cell phones can interfere with your car alarm system. It's
have a good day
Jan 18, 2011 | 2002 Jeep Grand Cherokee
The alarm clock on S5230 soemtimes work and sometimes it doesnot work, please help
Here's how you do it:
Menu--Alarms--Tap to create--Alarm Name and Alarm Time [the time you want the alarm to go off] (I'm sure you can fill that up)--Now here is the part where you are facing the issue--The Alarm Repeat--Now press the Week days Tab--Select Everyday if you want the alarm to repeat everyday or select alternate days--Click Save.
Now the alarm will go off according to your set schedule.
If you need more help on that do let me know.
Feb 07, 2010 | Samsung SGH-S5230 Cell Phone
Alarm doesn't work
I finally figured it out. I was setting the alarm for p.m., which isn't labeled such, instead of a.m., which is labeled. For example, the alarm might read "8:00", but that actually means 8:00 p.m.
Dec 21, 2009 | Brookstone Audio Players & Recorders
Car alarm
you need a satelite
May 31, 2009 | 2004 Chevrolet TrailBlazer
Car alarm on 2005 chevrolet cobalt
that is incorrect the alarm is jsut like any other it should only sound if there is a problem, which in this case there is, whoever you bought the car from is lying to you, i would have to say that the contrl module for passive alarm is bad
Apr 19, 2009 | 2005 Chevrolet Cobalt
Alarm system stoped working on 87 caddy fleetwood
First question , is it a FACTORY alarm or an AFTER MARKET alarm. Regardless, I haven't met an alarm yet, that protects the radio.. My guess is, that if it is an aft/market alarm, inadvertantly placed the system in the "VALET" where it doesn'i work. Let me know if you disconnected battery, and are there alarm toggle switches.
Mar 23, 2009 | 1995 Cadillac DeVille
Smartset cd alarm clock radio-no working alarms
I had this same problem. I removed the battery and then unplugged it for about a half an hour. When I plugged it back in, I had to reset the date, time, year, time zone and alarm times, but the alarms now work!!
Nov 09, 2008 | Emerson Smartset Clock Radio
Motorola RAZRV3x - alarm only works sometimes
TRY TO DELETE THE ALL ALARM FIRST THE NEW ALARM AND CHECK THE TIME AND ALERT SET UP IS CORRECTLY?U MUST CLICK THE DISABLE WHEN THE ALARM START WORK,THEN CLICK OPTION TO ENABLE TO CONTINUE USE IF u WANT SAME TIME ALARM WORK.DON,T CLICK SNOOZE WNEN ALARM START FUNTION.IF U REALLY WANT SNOOZE,PLEASE REMEMBER TO DIASABLE THEN ENABLE TO SET ALARM TO CONTINUE FUNTION.REPLY ME rose89my@yahoo.co.uk,thk!
Jul 21, 2008 | Motorola Mobility RAZR V3x Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
