Question about Torker Tri Star Rear Basket White Bicycle
In every gear if I hesitate pedaling when I resume there's free play for a quarter turn or so and then it will resume normally. This happens repeatedly whenever I 'coast' even for  moment
  • 192 Answers
Your free wheel assembly has play and simply needs to be reassembled. It is not an expensive fix if you wish to take it to a repair shop, or if you are mechanically inclined, you might wish to disassemble the rear wheel drum assembly, which includes the freewheel assembly and the gear spindle.
If however you do not feel confident in this procedure, you might opt to have a repair shop handle it. It is possible they may find a worn part in the freewheel assembly, but as stated before, most parts in the assembly are inexpensive.
Hope this helps. Thank you for using FixYa.
Posted on Sep 05, 2009
98 golf clutch pedal went to the floor. Car would not engage any gear. Fixed cable so pedal now feels good but still won't engage I can move gear lever any where, release pedal but nothing happens.
What do you mean when you say you fixed the cable. It sounds like the cable broke and you replaced it. Is that correct. If so, did you adjust the free play in the clutch pedal to the manufacturers specification. If you have not done this correctly the clutch will either not disengage, or no engage properly. From your description it appears as though there is n free play and hence the clutch is staying disengaged even when you release the clutch pedal. If this is the case, then try lengthening the cable until the clutch pedal moves with say 25 mm of free movement before anything happens, and try again.
May 19, 2016 | Cars & Trucks
Clutch pedal travel
Your pedal height may be adjustable by a stopper bolt at top of pedal. You would have to check the specification for your car. Most important that the pedal has about a half inch free travel before clutch begins to engage. You need that free play to ensure the release bearing (the throw-out bearing) is not touching the fingers on the pressure plate when not engaged. If it always is touching, it will be rolling around constantly and will go out prematurely.
Your new clutch will allow gear engagement sooner as the clutch pedal is released. I mean gears will engage just as pedal is lifting off from floor. You should notice that difference-the old clutch would have taken longer pedal travel from floor before releasing.
Apr 15, 2013 | Cars & Trucks
1999 toyota rav4 wont go into first gear, i just repaced the clutch,clutch slave cylinder and clutch master clutch
Did you bleed the slave cylinder? Also, check pedal free play (about 1/2 inch) and pedal height (not sure on your Rav, you'll have to check with Toyota).
Only first gear, or difficulty going into all gears?
Nov 25, 2011 | 1999 Toyota RAV4
I have a 2004 sunfire, it is a standard. when i switch from 3rd gear to 4th it makes a loud grind sound. it drives okay other than that, but what do you think it could be?
Does this noise only happen when switching between these two gears ? Also need to know how much play you have in the clutch pedal (push down on pedal, how far does it go down--free play?? plus when you release the pedal how far from the floor does it star to engauge ??) need to know these questions first before i can answer your question..ok..
Aug 18, 2011 | 2004 Pontiac Sunfire
Clutch stays down, has about half an inch of play below carpet level, still able to shift but have to use toe of shoe to pull pedal up. happens two or 3x a day
you have 4 cyl or V6 engine, how much free play you have on clutch pedal (take your hand press clutch in untill gets harder to push in) should only have about 1" free play, and also when you release clutch while in gear should start engaging about 1 1/2" up when releasing
Feb 04, 2010 | 1993 Toyota Pickup
2002 Sunfire
check automatic adjuster on clutch pedal under dash .
May 08, 2009 | 1997 Pontiac Sunfire
Torker Tri Star Rear Basket White Bicycle Logo
148 people viewed this question
Top Torker Cycling Experts
John Egan
John Egan
Are you a Torker Cycling Expert? Answer questions, earn points and help others
