Question about HP 1020 Plain Paper Thermal transfer Fax
The paper feeder in this fax machine won't feed, so faxes can't be printed
  • mwpalmer Sep 04, 2009
    Thanks for the help. I was able to un-jam the machine, thanks to your tips.
    Brigadier General:
  • 3,513 Answers
Technically, your machine is jammed. The paper is jamming as it exits the feed area, and enters the machine. Not being specifically familiar with that model, but rather based on experience with other similar machines with like problems, I would say you should look for 3 possible causes...
Most machines have, shortly into the paper path, and generally in the area you're indicating, some sort of sensor switch, whether it is photo-electric, or a mechanically activated toggle, that senses and registers the lead edge of the paper so the machine knows it did feed. This switch could be knocked out of place, or simply dirty, and not sensing the lead edge of the paper within a certain period of time after the machine registers the feed had been actuated.
A second possible cause would be (and you may be able to visually verify this) is that usually, in these types of machines, there is some sort of pressure or "******" pad/roller in conjunction with the feed roller. If this isn't working right, the machine may be feeding more than one sheet at a time, and becoming jammed in the paper path area due to "thickness".
A third possible issue could be an unremoved scrap of paper from a previous jam (or a staple/paperclip/piece of rubber-band/or any other foreign object, as I've seen them all) still remaining in a thin and obscure position of the paper path blocking the paper's progress to the abovementioned switch.
The original feed rollers are often internally spring loaded, or spring-loaded clutch driven for one way feed drive. Common problems are that the spring may have become "mal-formed", or dried up (they are general greased/lubed mechanisms). In either case, dis-assembly of the feed drive mechanisms for replacement or re-lubing is probably going to be required.
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
Open the control panel.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Thank you for contacting Fixya.com
Posted on Sep 04, 2009
Help-the paper feeder does feed the paper so the amounts print on top of each other.
If the document feeder is not feeding paper properly, the first thing I would suspect is the feed rollers ( 2 or 3 in total,) as they have the tendency to become dirty and worn. My suggestion would be to open the document feeder, take a clean rag and some general cleaner (no solvent,) and wipe down each roller as best you can. This will act to remove any trapped dirt or debris in the feed roller traction marks, and thus give you a more reliable document feeder. However, if this fails to alleviate the issue and the rollers appear worn, replacing them would be your next step.
I would suggest precisionroller.com as a good source for printer, copier, and fax supplies.
-David.
Nov 05, 2010 | Office Equipment & Supplies
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Hi my canon fax-jx200 keeps coming up recorded in memory..How do I retrieve it?? Many thanks, Lorraine
Hi Lorraine,normaly with this fax it have a auto print off setting that keep the faxes in memory.You can turn auto print to on by pressing the on/off button once less than a second,then it will switch to auto print on.
Let me know if you dont succeed.
Dec 03, 2009 | Canon FAX JX200 Fax / copier Plain Paper...
Paper won't feed through to print my faxes.The mechanism sounds like it is turning to pick the paper, but it isn't feeding through. As an alternative, can I use the USB port to copy the faxes onto a USB...
That model quite often breaks plastic parts that hold the gears together in the sheet feeder, a new sheet feeder will run around $49.00, there's no way to transfer faxes out of the machine without printing.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Auto paper feeder not taking paper
Try removing the paper, then removing the drum from the machine. Check to see there are no obstructions, then re-insert the drum, making sure that the gears mesh properly. Load the paper, setting the paper width guides and then try printing a report.
Nov 13, 2007 | Brother IntelliFAX 2800 Laser Fax
Feeder
Paper being printed or Sent? but prob Dirty feed roller (paper feed or doc feed roller)
Oct 11, 2007 | Brother MFC-8220 Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP 1020 Plain Paper Thermal transfer Fax Logo
46 people viewed this question
Seeker5211
Seeker5211
