My speakers work out of the headphone jack but not from the internal speakers.
  • beardown34 Sep 04, 2009
    None of the above and I have went into audio devices and switched setting to laptop stereo speakers as well.
    nope all is good there, do you have any instructions on how to get to the speakers to replace them.
    President:
  • 3,278 Answers
Be certain that Mute is not enabled.
Be certain that the volume is turned up.
If still a problem, what PC / laptop do you have ??
Hope this helps.
Posted on Sep 04, 2009
  • 1 more comment
  • NinaE Sep 04, 2009
    So, when you test Speech Properties ... no sound ??
    Check out Device Manager to see if any "?" in Sound Controllers. If so, Right-Click and delete or update the driver.
    Hmmm ... what system (brand and model) do you have ??? Thanks.
  • NinaE Sep 05, 2009
    Hi.
    Without knowing what system (brand and model) you have, I can't help you with the speakers.
    Do you still need assistance ?
No sound except through headphones
The fact that the device produces audio output through the headphones indicates that the audio system is operable up to the headphone jack. Therefore, the fault must lie in the internal speaker, the wiring between the jack and the speaker, or the jack itself. Most likely, the internal speaker has gone belly-up and needs to be replaced...
Mar 26, 2016 | Tablets & eReaders
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
Internal speakers are disabeled. Extearnal speakers work just fine
Headphone jack may be faulty as there is a contact that tells the uProcessor that the socket is in use and turns the internal speakers off. If the contacts are tarnished, they might not be opperating correcty.
Dec 03, 2013 | Computers & Internet
After installing the HP H8000 Wireless Headset the notebook internal speakers are not working on my HP ENVY dv6
When connecting a headset or any other audio device to a laptops 3.5mm audio jack, it is designed to stop the internal speakers and run only from Headphones.
If you mean that even after disconnecting the Headphones the internal speakers are still not working, ensure that the headphone jack does not have anything lodged in it, any metal object can trick the laptop into thinking there are headphones connected, cutting the internal speakers out.
Try getting a DRY cotton bud, and clean out the port with that, this will get rid of anything that may be triggering the problem.
Oct 16, 2013 | HP Wireless Headset H8000 opal
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
22 people viewed this question
k24674
