Last night in the middle of a wash load it just stopped working...full of water. When you turn it on it sometimes makes a humming noise for about a minute but then nothing.
  • 279 Answers
You are going to have to replace the motor, unless you can repair it. That humming noise is the motor trying to start. For some reason, it cant turn. May be the switch (in the motor), something may be jammed in the belt, the bearings may be bad. Open it up and see what it is...Lee
Posted on Sep 04, 2009
Frozen with spin and end lights lit whilst making a humming noise
sounds like motoer or transmission is sticking. could be a problem with control switch.
Jul 13, 2012 | Washing Machines
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Middle of cycle and won't start, just hums
You have a drain problem check the hose going to the pump.I bet u find a sock or such in it.
Nov 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool LSR7233000 Washing Machine
HI thanks for your question. i would look at the lid switch, you said you had an off balance load. that could have broken the lid switch. replace it thanks
Oct 26, 2007 | Whirlpool LSQ9610L Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
