Question about Rowenta Power Duo Iron
Wont turn on
I have the same problem, light wont go on wont heat, sometimes i can get it to flicker, still does not go on or heat up. i paid a lot for this iron and would not expect a problem like this.
    President:
  • 1,187 Answers
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Posted on Sep 04, 2009
I have two irons. one if them won't turn on anymore and i noticed the light kept fading out. the light on the other one flickers and it stops working halfway through straightening. any solutions?
Most likely it is the power cord. We have the same iron and the power cord has a break in it just as it comes out of the swivel. You can turn it on and hold the power cord tight up against the swivel and it should stay on. I was able to fix it by stripping the cord down to the wire soldering and adding shrink tubing to the connection. That lasted for about 1 year and it has done it again. I may have to replace it but not sure how to take it apart.
Sep 19, 2010 | Conair Infiniti Instant Heat Ceramic Hair...
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Light on Iron Flickers and Iron does not heat? Iron is 10yrs old.
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Feb 14, 2010 | Sunbeam Steam Master 4215 Iron with Auto...
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
Hair straighner .
Does not seam to "light up" ?
Light goes on ??
Not heating - but the light on ??
If so - the heating element has failed..
Time for a new one I am afraid ;o(
Aug 20, 2009 | Conair Professional Ceramic Hair...
Iron won't heat up!!!
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Jan 14, 2009 | Rowenta Power Duo Iron
Rowenta Iron problems
inside the iron is a thermal switch that has failed to make contact. Dissassemble the iron and you will see a small white ceramic pin sticking up out of the heating chamber and on tip there is a small contact. Above it is another contact that makes the heating element work. Easiest way to fix is to put a small bead of glue on the housing to force the contacts together.
Sep 02, 2008 | Rowenta DZ1700 Iron
The light is on...but no heat at all?
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Aug 10, 2008 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta Power Duo Iron Logo
473 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
