Question about HP DeskJet 940c InkJet Printer
I'm getting only blue ink when I print. what to
I'm getting only blue ink when I print. what to do>?
  • 106 Answers
Get ur printer cartridge refilled to get the full color or if the cartridge is old then replace the cartridge
Posted on Sep 04, 2009
Print Blank Pages not print by ink cartradge full
Here's a solution to your printer problem ;
Press the Ink button -> Test Print -> then choose Print Quality -> the printer will then go through and print a series of small squares in each of the four colors in the shape of parallelograms. If you see any gaps in parallelograms then you will be asked asked to clean the cartridge, do so. -> Just keep repeating process until there are no gaps
Then I did an Alignment check right after the cleaning through pretty much same process:
Press Ink button-> Test Print -> then choose Alignment-> and make sure the patterns match to the closest number
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For :Brother Printer Support
Sep 14, 2012 | Brother Ink for Dcp145c Lc-980
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
When printing, the blue color is missing
Make sure your print cartridges have enough ink in them for printing.
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to fix the problem:
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working color cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X1190 All-In-One InkJet Printer
Epson sx210 inkjet printer trying to change black ink cartridge but can't find how to get print head to move to correct position to remove cartridge.
If you're using Windows,
XP : Click Start, go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My printer is running low on black ink and i'd like to use blue
Sorry but you cannot select the default color. What you can do is to set the color or your text in navy blue.
You can also select color cartridges only from: Printer Properties -> Mainteinance -> Ink Cartridge Settings.
And then from Main tab select Grayscale Printing.
Good Luck.
Jun 23, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have a Phaser 8550. That will not print any magenta/ pink. The test prints for that color come out purple. I check the ink resevoir on the print head, I didn't see any blue in the well. Any ideas
on the control panel go to trouble shooting > printing problems > advanced
If this doesn't get the ink flowing make sure you are not low on ink by checking the loader and if that is not it check the loader for cracked ink chips in the loader which may be preventing the ink from getting pushed down onto the melting mechanism. I had that problem once and fixed it by shutting the printer off, letting it cool and then laying it on its back side with front up in the air with ink loader open fish out the ink sticks and visually check for broken off ink chips and if none are seen. Do what I did out of frustration, unplug the unit and thru the holes in the ink loader stick a screwdriver in there and try to "lightly" scrape any petrified ink that may be stuck and not clearing out. I did this, felt a little resistance but no chunks or anything broke loose however the problem seemed to have been cured. I suppose I broke some ink loose after all. Good Luck.
Apr 15, 2010 | Xerox Phaser 8550/DT Thermal Printer
My blue color does not print
Remove the Color and Black Cartridge >
Remove the Printhead by pushing the grey latch with your thumb going upwards
close the access door without nothing on it
unplug your power cord > re connect after 10 seconds
reinsert Printhead and Ink cartridges
goodluck....
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
May 29, 2009 | Canon PIXMA MX300 All-in-One Printer
Can't print without black Ink
From HP's website:
The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges.
Try this::
Leave the empty cartidge in and go to print, select the printer, click on preferences, then the paper/Quality tab. there select color and best. This way you wil be able to print your document.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2008 | HP Photosmart C6280 Printer
HP DeskJet 940c InkJet Printer Logo
134 people viewed this question
Seeker5211
Seeker5211
