Question about Canon i9900 InkJet Photo Printer
Paper does not discharge completly - Canon i9900 InkJet Photo Printer
Should the v8 remain charging when not in use?
If the battery is Li Ion then they can be charged at any point, if Ni Cad discharge fully before recharging.
Oct 20, 2016 | Computers & Internet
My kobra shredder won' shred when we put paper in lights are on
Is the discharge at the bottom where the shredded paper comes out clear? If its blocked by paper etc, it will not shredd.
Aug 19, 2014 | Office Equipment & Supplies
Ir400 fan numbers
II. FANS
A. Arrangement and Functions
Feeder fan
Fixing assembly heat discharge
fan 1***
fan 2 ***
Laser driver cooling fan
Laser scanner motor cooling fan 1
Laser scanner motor cooling fan 2
Cleaner heat discharge fan
System cooling fan
Reversing guide cooling fan
Low-voltage power cooling fan 1
Low-voltage power cooling fan 2
Reader cooling fan 1
Reader cooling fan 2
Drum cartridge cooling fan 1
Drum cartridge cooling fan 2
Drum cartridge cooling fan 3
DC controller PCB cooling fan
Scanner motor cooling fan
Function
Draws copy paper to the feeding
belt. Helps feeding.
Discharges heat from around the
fixing assembly.
Cools the laser driver PCB.
Cools the laser scanner motor.
• Cools the laser scanner motor.
• Insulates the drum cartridge
against heat from the fixing
assembly.
• Discharges heat from the
drum cleaning assembly and
fixing assembly.
• Discharges heat from the DC
controller PCB.
composite power supply and the
DC controller PCB.
Prevents curling of paper.
Discharges heat from the lowvoltage
power supply.
Cools the reader (image processor
PCB, laser driver PCB).
Cools the drum cartridge.
Cools the DC controller PCB.
Cools the scanner motor.
Aug 28, 2012 | Canon imageRUNNER 400S Copier
Ijustbought a newbattey for my acer aspire 6920 laptop. Iinstalled it and it said 61% available, I let it charge all night and all day untiljust now 7pm. and id still says 61% and charging . the old one...
First try a REFRESH by discharging it COMPLETELY than re-charging it COMPLETELY (do that 4-6 times) nice week end project ha!, than if it still won't charge completely ASK FOR A REPLACEMENT OR REFUND... (if it's new it should be under waranty)
May 26, 2011 | Computers & Internet
CO2 compleetely discharges when trying to install
Hi Ken.....Sorry to tell ya, the gun is a dud. I Had the EXACT same problem, I got only one good co2 out of the gun, then that was it. I returned it, and this one is great....dead on accurate bud, providing you are a good shot to start with. And If You Use The BB's, you will find that it is powerful also; as i only use the pellets for paper targets. Have A Ball.. -**** J- Connecticut
May 30, 2010 | Daisy Toys
Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Mar 25, 2010 | Canon Office Equipment & Supplies
Prinert prints fine then catches on top right hand side
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd1
May 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Battery Discharging when pugged off
Pls check with the local service center for battery or go for a new battery........................Sameeraryan
Jan 15, 2009 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Battery wont charge
The batteries are probably worn. Age, failure to completely charge, frequent discharging to below 50% of charge, completely discharging, and heavy use all contribute to wearing out a battery. The most common symptom is the one that you have; the battery will not completely charge.
Nov 02, 2008 | Pride Health & Beauty
Canon i9900 InkJet Photo Printer Logo
42 people viewed this question
old marine
old marine
