Question about Whirlpool Duet GHW9150P Front Load Washer
Duet Dryer will not start, Press control on, Start, then it beeps
It beeps and then the sensing light illuminates. Will not start the drying cycle at all. Unit is approximately 5 years old.
  • 3 more comments
  • dondo Dec 14, 2007
    I had a few power dips yesterday (ice storm) while dryer was running now all the lights seem to function but when start is pressed sensing light comes on and that is it. Removed power for several minutes to no avail.
  • tutorisland Dec 27, 2007
    a week ago there was no hot air
    i checked the two thermal sensors
    one was open
    so i replaced both
    everything was working
    until the 6th load where it went into shutdown
    i mean sensing light lite n dats it
    i can cancel cancel n get it to change normal - timed [whatever]
    but can not get her to spin/dry
    funfit35@hotmail.com
  • racerswife94 Jan 25, 2008
    I have had the same problem with our dyer. We bought it from a "repair" guy. The set has only been used a total of 5 times. 2 X by us. The first time we used it the dryer ran most of the cycle then shut off and flashed the F70 code. The "repair" man came and replaced the entire brain in the dryer and we just hooked it up and it did it again same thing. Ran most of the cycle then shut off and flashed the F70 code. Any idea what could be wrong?
  • Antanie May 30, 2008
    Whirlpool Duet dryer WED9200. Press Power then Start and it will not start. The sensing light comes on and then nothing. I have tried to reset by the circuit breaker, but it does not help. I have had this unit for just over a year. What can I do?
  • Anonymous Mar 16, 2014
    When I press the start button it beeps once and the sensing light comes on. And then nothing
  • 36 Answers
Try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
Posted on Dec 28, 2007
Dryer won't start, push the start button it just beeps
It is possible you have a broken drum belt. You may need to call a qualified service man as changing a belt can be tricky.
Oct 01, 2015 | Whirlpool Duet WED9550WW 27" Electric...
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Can not get my dryer to turn on
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Whirlpool dryer
is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Mar 11, 2008 | Whirlpool GEW9250P Electric Dryer
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
846 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
