Question about Thermador PD304BS Dual Fuel (Electric and Gas) Kitchen Range
Oven wont heat up. Starts to heat and the flashes lights in a pattern. oven light lights 4 times, then the heating light lights three times and repeats over and over. Any ideas?
  • 2,200 Answers
Your oven is actually flashing out a sequence of numbers than can be converted into an error code and read by a technician.
Some errors must be cleared by turning off the oven at the circuit breaker and then turning it back on. When an error remains displayed steadily after attempting to clear the error, a service call is required.
There should be an explanation of the error codes on the wiring diagram that comes with the stove. This wiring diagram is usually taped to the inside of the kick plate. The kick plate has to be removed to find it.
As a suggestion these ovens often have problems with error 34 - that error code indicates that the computer is not recognizing that the cooling fan is operating and the oven will not work (your error however, appears to be 43 so observe the sequence carefully to be sure it is not inverted) .
If you cannot find the error diagram behind the kick-plate you can call Thermador Customer Service toll free at 1-800-735-4328.
In any event if this error fails to resolve after disconnecting at the circuit breaker a service call is required.
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 04, 2009
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Oven wont turn on,preheated light keeps flashing when turned on
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 15, 2011 | Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Open Questions:
Thermador PD304BS Dual Fuel (Electric and Gas) Kitchen Range Logo
140 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
